Why are semi fuel tank fillers not designed the same as automobiles?
Discussion in 'Experienced Truckers' Advice' started by TruckRunner, Dec 7, 2018.
  1. TruckRunner
    TruckRunner Heavy Load Member
    704
    3,270
    Dec 21, 2017
    Semi fuel tanks just have a hole with a scree cap while automobiles have it to where you insert the nozzle which is held steady and stops when the tank is actually completely full. No worries about spillage or nozzle falling out. Why aren't truck fuel tanks designed the same way? Is it to save a few dollars or because truckers cried when they made it better and wanted the primitive design like the 80s style trucks they drive around in? I don't understand that fascination I wouldn't buy a 2019 car that looks like its 40 years old but that's another topic.
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    No standards set for the nozzle sizes on pumps.
    WildTiger1990 and TruckRunner Thank this.
  4. keebler13579
    keebler13579 Heavy Load Member
    949
    1,862
    Nov 16, 2012
    Truck diesel pumps also pump a lot faster have to displace the air faster
    JReding, misterG, brian991219 and 7 others Thank this.
  5. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Well if you fuel at the pumps designed for trucks, the nozzle has a nice lip that catches on the tank and it doesn't fall out, they also pump about 3 times faster than the car pumps.
    Dan.S Thanks this.
  6. Chinatown
    Chinatown Road Train Member
    74,915
    170,758
    Aug 28, 2011
    Henderson, NV & Orient
    The nozzle won't fall out if you use a tarp strap to hold it in.
    If the nozzle jumps out, that's your fault, not the truck manufacturer.
    JReding, Blackshack46, Dan.S and 2 others Thank this.
  7. TruckRunner
    704
    3,270
    Dec 21, 2017
    Not all of them have a nice lip. I am just saying its easy to fill up a car you stick it in and pull it out when done like sex.
    D.Tibbitt Thanks this.
  8. D.Tibbitt
    148,552
    Hell sometimes im done even before i get to stickin it in
  9. otterinthewater
    5,535
    29,096
    May 10, 2018
    Santa Barbara, Ca
    I think they make medications for that now. At least that’s what I heard. I have no practical experience with it.
    Please don’t ask my wife.
    Hahahahaha
    Hammer166, Woodys, not4hire and 3 others Thank this.
  10. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Not that many years ago some cardlocks had a nozzle that was 1.5 wide or so .. also when draining a tank for repairs they often use a fair size hose to siphon our the fuel .. another possible reason is the current setup seals better in case of a rollover or accident than it would with a car style filler neck
  11. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    That’s exactly why. The filler necks cause fuel to backup and you get wet feet. My old ‘41 pickup can’t take fuel at full volume from pump. Got to dribble it in. Old pumps moved less volume
    Dan.S Thanks this.
