Why are semi fuel tank fillers not designed the same as automobiles?
Discussion in 'Experienced Truckers' Advice' started by TruckRunner, Dec 7, 2018.
  1. wis bang
    wis bang Road Train Member
    3,393
    3,996
    Jan 12, 2011
    Levittown, PA
    we get re-fuled by a vendor at night using a bobtail heating oil style truck and a 2" nozzle...size matters!
    D.Tibbitt Thanks this.
  3. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    I filled up there because it was 2.50 a gallon, ain't passing that up.
    Chinatown Thanks this.
  4. Bill51
    Bill51 Road Train Member
    1,180
    2,973
    Jul 27, 2015
    Wanna really feel uncomfortable? Bought the GF a new Ford Fiesta. There is no cap. You open the little fuel door (hatch, panel?) and bam, there's the filler with no cap on it. The little fuel door is supposed to seal it when closed. Every time I put gas in that car, it bothers me.
    D.Tibbitt and stwik Thank this.
  5. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    Another "better idea from Ford"?
    D.Tibbitt, magoo68 and Bill51 Thank this.
  6. Bill51
    1,180
    2,973
    Jul 27, 2015
    The device was wired for 110. He forgot that we use 220.
  7. DougA
    DougA Road Train Member
    1,429
    8,892
    Dec 16, 2013
    Retired,In my shop in Md.
    I used to really like the large size of the fuel tank caps on my old 4300 Internationals. You could easily remove the cap,stick your hand and arm in the tank with a new spin on fuel filter,dip it in the fuel to fill it up,and pull it and install. No fuss,no muss.
    adayrider, D.Tibbitt and stwik Thank this.
  8. tscottme
    tscottme Road Train Member
    Diesel isn't as volatile (doesn't rapidly evaporate) as gasoline. Gasoline fumes contribute to the type of air pollution the EPA measures and EVERYBODY has a car (gasoline).
    Gasoline nozzles & hoses may also have a vapor recovery feature that isn't on diesel nozzles/hoses. Not EVERY difference between car drivers & truck drivers is a vast conspiracy against truck drivers even if it's the #1 theory on trucking radio & message boards.
    stwik and TruckRunner Thank this.
  9. Long FLD
    Long FLD Road Train Member
    11,901
    48,877
    Mar 4, 2015
    That’s how my 2016 Dodge was. There’s another little flap down in the fill neck. When it was cold I had to stick a screwdriver down into the neck to open the flap to dump Powerservice in otherwise it would just hit the closed flap and drain out onto the ground. Ask me how I learned that. Lol
    Ruthless and D.Tibbitt Thank this.
  10. SteveScott
    SteveScott Road Train Member
    4,897
    16,806
    Nov 10, 2015
    If you spit on them first, about any size will fit. Wait, what are we talking about again?
  11. Hammer166
    7,458
    27,032
    Aug 18, 2007
    ~8600+' and loving it!
    Also, think about how high the nozzles would be if a truck had a proper filler neck!
    magoo68 Thanks this.
  12. adayrider
    adayrider Road Train Member
    1,289
    1,732
    May 7, 2018
    No that's a different problem, that problem means you will never stick it in unless you take the medicine.
