Why aren't logs required for local work?
Discussion in 'Questions From New Drivers' started by ad356, Sep 22, 2017.
  1. ad356
    ad356 Road Train Member
    2,138
    3,179
    Mar 13, 2017
    This is in no way a suggestion to the dot, but why aren't logbook required for everyone driving any type of cmv. As a local driver I am exempt from h.o.s., we don't have logbook or elds of any type
    Why? Or is this garbage coming down the road for us local guys and gals?
  3. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    Don't worry, be happy.:)
    Toomanybikes, Grubby and pattyj Thank this.
  4. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    it has to do with "air miles" and hours you work. if you travel under (i think) 100 air miles, no log. if you work under (i think) 12 hours, no log.
    someone more familiar with this can chime in. i need to do a log myself as i put in 300 miles (round trip) nightly, but under 9 hours (most nights)
  5. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    See you are not exempt from hos. You are exempt from needing to keep a full grid log if you meet all three criteria.
    1. No more than 12 hours working.
    2. Less than 100 air mile radius
    3. Start/stop in same location.
    If you meet all three you can do a timecard, instead of a full graph log. Remember though you still need to be aware of your 60/70 hour clock. It is still in affect.
    heyns57, Longarm, tscottme and 3 others Thank this.
  6. ZVar
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    As for the question asked, could you imagine what a graph log would look like for a local delivery guy with 28 stops....
    DTP, strollinruss, Longarm and 4 others Thank this.
  7. buddyd157
    13,582
    34,899
    May 25, 2017
    under a shade tree
    well when i ran the road and had to make multiple stops, especially in the same city, i went down to line 4, on duty, not driving and stayed there, then i had to flag from the start of that till the end, then go back up to driving line. all i had to put down was "all city driving, Allentown, PA".
    TaterWagon#62 and wis bang Thank this.
  8. ad356
    2,138
    3,179
    Mar 13, 2017
    While I not might be exempt from h.o.s. i don't see how it would be enforced. I have been lucky to never been stopped by dot, we all know thats hassle. I work 8-10 hours per day so I'm not in violation.
    Does the DOT ask you for a time card or something?
  9. Ridgeline
    22,773
    124,495
    It depends on a few things, one is can you put 30 stops on a log?
    If you can, then can they be read?
    OK seriously this is a long explanation.
    There is an issue with the way the regulations were imposed onto the states, the FMCSA, or at the time the ICC had limited powers (and still does) to tell the states what they can do within their borders and the state in truth can ignore the ICC/US DOT/FMCSA regulations to a point. A state can require logging for one or another truck, define what a truck is or isn't and so on. We have some odd issue of what a CMV is here, with five, FIVE different definitions based on both weight and licensing and they all conflict.
    The states agreed to follow the HOS back in the 1930's as part of the driver protection the HOS was created to do and it worked. The ICC (and congress) at the time had push back by the states with some exemptions and there were I think 300 different requests made for exemptions like those for borax trucks, and another for peach trucks and so on. So congress said, we will just give a mileage exemption but they have to limit the hours worked with no need to log the time other than a time clock.
    Then the states later agreed to adopt most of the other federal regulations after the war because of the horrible mess that came about during the war (a lot of drivers were killed by the lifting of HOS and safety requirements in '42 - '44), so one centralized means of regulation creation and approval is not needed through this agreement, they are just adopted by the states automatically. The states still can opt out of this but then they have another issue with another agreement between all the states that will stop that.
  10. ad356
    2,138
    3,179
    Mar 13, 2017
    Very interesting history
  11. Alaska76
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    They ask where are you coming from and where are you going. Or, they may ask if you are keeping a log book. You answer and include the fact that you are run local and are not required to keep a log due to the fact that you remain within the 100 air mile radius, end of story.
    That has always been my response and the DOT officer has never taken it any further.
