Why did the po use wood in the battery box?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by sarrattseptic, Nov 6, 2021.
  1. sarrattseptic
    sarrattseptic Bobtail Member
    49
    25
    Aug 21, 2020
    Waynesville, North Carolina
    I removed my batteries to charge them at home and the previous owner had a number of pieces of wood in the box. They had been there for years. They were between the four group 31 batteries (one box on each side of the truck).
    My first thought was to throw the wood away, but I suspect these are here for a reason.
    Cooling?
    Lift the battery out of water?
    The first pic is the driver's side battery box. I don't have a pic of the wood; it was just some some cut 2x8. Ignore the white pvc pipe in the picture; it just happened to be laying on the box.
    The passenger side battery box is shown with the metal lid (under the shovel).
  3. Chinatown
    Chinatown Road Train Member
    75,627
    172,964
    Aug 28, 2011
    Henderson, NV & Orient
    Probably 2 reasons; to keep the batteries from moving and to prevent galvanic corrosion which is caused from dissimilar metals coming in contact with each other.
    LoneRanger, skallagrime and Last Call Thank this.
  4. Lazer
    Lazer Road Train Member
    1,802
    2,872
    Jan 22, 2017
    More than likely, when this truck was new there was ‘hold down brackets’ to prevent the batteries from bouncing around.
  5. REO6205
    REO6205 Road Train Member
    13,171
    60,501
    Feb 15, 2014
    California.
    Batteries are heavy. A lot of battery boxes are made out of thin material. A piece of wood under the batteries helps distribute the weight of the batteries.
    beastr123 and skallagrime Thank this.
  6. skallagrime
    skallagrime Road Train Member
    3,856
    9,943
    Apr 10, 2012
    Indiana
    Also acts as a vibration dampener and electrical insulator, rubber would be better, but wood is easier to find
  7. REO6205
    13,171
    60,501
    Feb 15, 2014
    California.
    Rubber is definitely better. Our mechanic favors old pieces of mudflap or conveyor belting.
    spindrift, beastr123 and Rideandrepair Thank this.
  8. Dave_in_AZ
    395,685
    How is the metal in the bottom of said box?
  9. SmallPackage
    5,531
    17,612
    Dec 20, 2019
    Marion Texas
    Lots of older trucks used wood box floor and battery seperators from the factory. Just like many had plywood cab floors. They actually rotted less then the aluminum and steel ones. Battery acids will eat thru aluminum pretty quickly even if the batts or sitting on rubber mats.
    Frieghtliner stiil had plywood battery box floors on some of their models up to 2003. Our bussiness class trucks did.
  10. Rideandrepair
    17,356
    56,314
    Aug 8, 2015
    I use a big thick
    Mudflap. And a small ratchet strap. Old hold downs alway get corroded and make changing batteries a hassle. A piece of rubber or old memory foam between them doesn’t hurt. Spacing seems to keep them in place, firmly on the bottom. A small piece of wood on top in the middle of both helps also.
  11. sarrattseptic
    49
    25
    Aug 21, 2020
    Thank you! I don't know. I did not think of that.
    I will lift out the pan which is on the bottom of the battery box.
    Dave_in_AZ Thanks this.
