why did they use too make 15 speed trannys then stop what were they made for if the use too makethem
Discussion in 'Experienced Truckers' Advice' started by piston757, Aug 17, 2019.
  1. piston757
    piston757 Bobtail Member
    33
    25
    Jun 5, 2019
    lubbock, tx
    just wondering why they use too make 15 speeds then they stopped what where they made for off road or heavy heavy loads or is it a good nonstop on the road tranny like the 13 and 18 speeds I just want too know about that tranny
  3. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    One of the toughest trannys there is, and great for anything you can do with a truck, You just have to shift every gear and do not have any half gears like a 13 or 18.
    D.Tibbitt, Intothesunset and Oxbow Thank this.
  4. AModelCat
    159,118
    Its basically a 10 speed but with a 3 speed aux section instead of a 2 speed. Its called a 15 but in reality if you started in the lowest gear and progressively hit every gear you'd only use 12 gears. You'd shift through all 5 in deep reduction, flip the blue button to go into low range and shift to 4th in the main box. Then you'd hit 5th, flip the range selector and then shift all 5 in the main box. 3 of the ratios overlap, so they aren't actually useable if you were to shift the way I describe. In most cases I'd just drive it like a 10 unless you needed to start out in a hole or on a steep grade.
    D.Tibbitt, stwik, LoneRanger and 8 others Thank this.
  5. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Yep on pavement it is a 10 speed, unless you are having to start a heavy load on a serious grade. On a typical interstate freight truck, you would not use the deep reduction gears much at all, and even if you do, you don't need to go through all five in it, just shift three change range and go back to the last gear you were in.
    Intothesunset Thanks this.
  6. piston757
    33
    25
    Jun 5, 2019
    lubbock, tx
    o ok and just to make sure I got it right bc I can just start at 6th and drive it like at 10speed unloaded but if I have a load on it then would I have too use any of the first 5 gears or could I still start in 6th gear just making sure and thank yall for the replies also they made the 15 speed for heavy loads y did they stop making it and is it a good long haul tranny?
  7. dibstr
    dibstr Road Train Member
    1,308
    932
    Sep 10, 2010
    Why do you think they have quit making them? Fuller has 5 or 6 series of 15 speeds still in production.
    Deep reduction is labeled 1-5, direct 1-5 and 6-10. If you do not use D/R you would usually start in 1st or 2nd direct, not 6th.
    Oxbow and Long FLD Thank this.
  8. AModelCat
    159,118
    Just don't put it in deep reduction and start out in low range. Pretend the blue button isn't even there. It has an interlock similar to the 13 speed. If deep reduction is selected you will not be able to lift the range selector switch.
    Intothesunset, okiedokie and Cat sdp Thank this.
  9. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Low is not actually6th even if you go through all the gears in deep reduction. If you do go through all 5 gears in deep r, you shift from 5 back to 4 in low range. if you just use 3, then you shift back to 2cnd, if that makes sense, it is easier to show someone than it is to tell them. lol
    Is yours up against the dash in high gear or normal?
  10. piston757
    33
    25
    Jun 5, 2019
    lubbock, tx
    ya mines up against the dash and ok thanks for input
  11. piston757
    33
    25
    Jun 5, 2019
    lubbock, tx
    also if I have my own truck and my cdl but no experience should I work for a company with my truck or use a freight broker or load borads with no experience I know that's wer the bigger money and all that is so I bought and now own a payed off 1996 Peterbilt 379 EXHD what do I do after I get insurance and all that stuff where do I start working or get work
    D.Tibbitt Thanks this.
