Why did we stop using a single giant battery, and now use 3 tiny batteries?
Discussion in 'Ask An Owner Operator' started by scoobertdoo, Dec 1, 2022.
  1. Opendeckin
    Opendeckin Medium Load Member
    454
    1,268
    May 20, 2018
    I lift weights and can deadlift 450lbs for 5 reps so 4 batteries ain't too bad. Not even a full 5 rep set lol.
  3. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    I deadlift 325 pounds from bed each morning.
    #### I need to lose weight.
  4. Jubal Early Times
    3,069
    20,583
    Oct 17, 2022
    What truck is running group 24 batteries? Group 31 has been the industry standard for decades now.
  5. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    Group 31 is 5 percent greater capacity. My last purchase I don't know what I got, 3 of whatever cost $89.
  6. Jubal Early Times
    3,069
    20,583
    Oct 17, 2022
    What’s the CCA on it?
  7. Jubal Early Times
    3,069
    20,583
    Oct 17, 2022
    I’d like to see 4 group 24 in your battery box. How did you rework the hold downs?
  8. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    2000ca
  9. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    They could be group 31 for all I know. My hold down is simply a bar going across the top of all three batteries
  10. 86scotty
    86scotty Road Train Member
    4,511
    12,219
    Aug 27, 2017
    Appalachia
    Here's the answer to the title of the thread. Industry standard. It has to do with what is the best fit in the most vehicles (a lot of them commercial but not necessarily trucks) so over time battery OEM's make more of these which makes them cheaper/easier to make which bleeds over in to how the trucks are made (the actual battery trays designed to hold them) which bleeds over in to what dealers/truck shops are most likely to supply because they buy them by the pallet.
    I like 4d batteries and put them in lots of stuff but it might make more sense to ask why water doesn't flow uphill.
  11. m16ty
    m16ty Road Train Member
    2,274
    4,963
    Jan 22, 2016
    Really old trucks sometimes had 6v batteries wired in series to get 12v.
    The main reason for group 31 is availability and standardization. Group 31 is used in pickup trucks, farm equipment, and all types of construction equipment. They are universal because of you just have a smaller engine to start you can use 1 battery, and just keep adding barriers at electrical needs increase for bigger vehicles.
    A main improvement for class 8 trucks would be to switch to 24v. 24v starts a big engine so much better than 12v, you can use smaller wiring, and you don’t have near the voltage drop running wire long distances.
