Why Do The Nice Trucks Have Spread Trailer Axles?
Discussion in 'Ask An Owner Operator' started by Perilously9, May 30, 2019.
  1. Perilously9
    Perilously9 Bobtail Member
    8
    6
    Apr 4, 2019
    Hackensack NJ
    I’ve always noticed that the “nicer” trucks on the road have always been pulling a spread axle trailer. Some of them are reefers, but many are not.
    I know that some of these trailers are just flat beds with a tarp surround it, making it look like an enclosed trailer. I could understand the spread axle there as flat beds need to balance weight to not be overweight, but what about the reefers and dry vans?
    I’ll put some pictures here so you can see what am saying.
    Google Image Result for http://www.tenfourmagazine.com/feature/2010/JuneCvrPic04.jpg
    So my question is, why are the running split axles? Is it just the aesthetics? Also do the trailer have smaller tires than the ordinary tandem trailer tires? It looks smaller in the picture but it could just be my mistake. Thanks!
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,636
    Feb 6, 2016
    Cant see your pictures but Im guessing you posted pictures of long wheelbase pete's and KW's and the reason for the spread axle trailers to to load rear heavy on the trailes as most of those type of trucks run 12-13,000 on the steers empty so they cant add any more weight.
  4. LDLWells
    LDLWells Heavy Load Member
    782
    1,218
    Jan 14, 2019
    You can run 40k on the the spread axles. Makes life easier
  5. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    As stated you can run 40K back there and not worry about shifting or breaking scales and get cited. Provided you remain under 80K and so on.
    Maintenance is essentially zero if you have a dump valve in tractor to allow the rear spread to float with very little scraping for docking etc Or making tight U turns etc.
    Appearances are not that important function is.
    scythe08 Thanks this.
  6. Dave_in_AZ
    390,084
    That's where the big money is.
  7. tucker
    tucker Road Train Member
    12,647
    40,423
    Jun 13, 2008
    IN
    I thought the hood trucks were way lighter on the steers than the slopes.
    D.Tibbitt Thanks this.
  8. Rideandrepair
    17,348
    56,286
    Aug 8, 2015
    Nope, it’s harder to shift steer weight, due to the distance or long wheelbase.The spreads fall into the 20 k rule, same as a single axle, instead of (17+17)34k tandem rule. Plus they ride better, but the real reason is to look cool. Lol
    Midwest Trucker and tucker Thank this.
  9. Ruthless
    Ruthless Road Train Member
    8,957
    88,263
    Aug 28, 2010
    The City.
    They are.
    265” L model, my steers run 10,000 on the daycab. Spread axle is the only way to get to 80k with a healthy load on a flat/step. Can’t get 12/34/34 if the steer is 10,500. I ran my fifth wheel all the way forward with 50k on the deck. Only put 500lbs more on the steer.
  10. Not pretty but it paid well and was 36k just as it sat. Spread could handle 40k.
  11. QuietStorm
    QuietStorm Heavy Load Member
    899
    1,416
    Dec 11, 2016
    The only reason everyone isn't using 48' trailers with spread axles is because big companies:
    1: are tired of steering wheel holders tearing off the tires turning too sharply,
    2: the very small extra $ that 5' gives them throughout the life of the trailer, and...
    3: for some reason certain shippers have started requiring 53' trailers for 45' loads.
    Otherwise, it's really the best.
