Why do Volvos old or new, constantly run the air compressor?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by trucknguy, Nov 3, 2025.
  1. trucknguy
    trucknguy Medium Load Member
    678
    1,773
    Mar 19, 2015
    West coast
    Why do they seem to constantly run the air compressor? No matter the age, I’ll have one park next to me and it’s worse than a reefer. Every minute or so the compressor kicks on then spits. They can’t all have air leaks. Anyone??
    taxihacker66 and Concorde Thank this.
  3. Big Road Skateboard
    6,618
    37,125
    May 2, 2021
    Cause a lot of the Volvo crowd don't maintenance much.
  4. Brandt
    Brandt Road Train Member
    4,588
    6,297
    Sep 17, 2012
    Volvo was also one of the first to use the plastic quick air connections. They seem to leak more as they get older. They use build trucks with copper connections and crush pressure washers or whatever it called. You could only really use them once but they would not leak. Now I think ever truck builders seem to use them. Freightliner dose anyway.
    Bean Jr. Thanks this.
  5. 201
    201 Road Train Member
    12,607
    25,878
    Apr 16, 2014
    high plains colorado
    Well, to be clear, it's not the Volvo, it's the poorly maintained air dryer, and probably air leaks. Not Volvo specific.
    hope not dumb twucker Thanks this.
  6. SmallPackage
    5,639
    18,025
    Dec 20, 2019
    Marion Texas
    Like @Brandt said. Mack does it also. They have a junction block under the cab that is next to impossible to get too. It has a dozen or more plastic crappy airline connectors in it that leak.
    Oxbow Thanks this.
  7. wichris
    wichris Road Train Member
    4,422
    9,045
    Jan 17, 2011
    Plastic body, a couple lines can be changed to compression fittings or buy a whole new body.
    Oxbow Thanks this.
