Why doesnt signal light flash when lights are turned on ???
Discussion in 'Kenworth Forum' started by Leilo, Feb 16, 2014.
  1. Leilo
    Leilo Bobtail Member
    My lights are on but when I turn on right signal light they dont flash on right side but when lights are offthey do
  3. CargoWahgo
    CargoWahgo Road Train Member
    3,912
    3,945
    Jan 10, 2012
    Louisville, Kentucky
    Is your signal working?
  4. Leilo
    Yeah they work wen lights are turned.off
  5. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    sound like you have a bulb where the flasher element is out or a wire touching where it should not be. it is going to be on your right side on one of your turn signal lights only. unhook trailer lights to see if it is on the tractor or trailer.
  6. Leilo
    I descanected e trailer and no the trailer is good look like its just the truck
  7. wonderdog24
    wonderdog24 Medium Load Member
    377
    127
    Mar 1, 2012
    Puyallup,Wa
    Turn signal harness has 3 wires.... Ground-Running Light-Blinker...... When your signal is blinking with the lights on does the whole light go dark??? Check it with your 4-ways so you can compare it to the other side easily... Assuming your talking about the front of the truck.... Or is it on both the front n back??
  8. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    I have a Pete that did that. Replaced all light bulbs, and turn signal relay. Fixed problem
