Why is everyone afraid of making fuel lines?
A complete hydraulic place did everything short of throwing me out the door the second they heard i needed fuel line, its literallly the same machinesand fittings, the only difference is fuel rated hose, and most high temp hydraulic lines ARE fuel rated.
I tried napa, carquest, 2 hydraulic places
The only place i found that would even tackle it was a john deere dealership that had em made in 15 minutes, but then this time around, i nearly got the run-around about not not making fuel lines until i told them the line they made last year for my truck was doing just fine... (upon getting the hose i looked up use, and it explicitly stated it was diesel rated
Is there seriously a GOOD reason for this, or just another example of forcing people to buy steeply overpriced badly designed oem parts?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by skallagrime, Mar 5, 2016.
Page 1 of 3
Most likely it's insurance related , several atv shops I use will make throttle cables and clutch cables all day long but if I ask for a brake cable they laugh me out of the shop
Those hoses are not DOT rated and hydraulic line is not fuel line.
WitchingHour Thanks this. -
You can buy the hose and fittings and make them yourself...... Unless your afraid.
Reusable fittings .
It's not hard.
Actually I like the new plastic fuel line on the newer trucks. Lasts forever and easy to use.
Just route it good so no rubbing and your set.Oxbow Thanks this. -
Our local hydraulic hose place has no problem with fuel lines, but they will not make power steering lines!
Yup, I've had them made at a hose shop without a problem. Rated for diesel. Way, way cheaper than going to a truck dealer.
May be an insurance issue. Lookup the type of hose you want to use and just ask for that, don't mention fuel if you are sure of the type of hose you need.AModelCat Thanks this. -
'Cause i don't know what i'm doing. How much pressure do the hoses/lines need to be rated at?
Also can a line for gas also be used for diesel and vice-versa?
Page 1 of 3
