Why is Peterbilt backwards?
Discussion in 'Peterbilt Forum' started by rwdfinch50, Aug 16, 2012.
  1. rwdfinch50
    rwdfinch50 Medium Load Member
    527
    595
    Nov 6, 2007
    Leesburg, Fl.
    I have two friends who just got new Petes. One is a 379 and the other is a 387. both trucks came from the factory with the DEF tank on the right side. Why is this when every other manufacturer is putting it on the drivers side. Plus, all of the truck stops are equipping their pumps with the DEF on the drivers side. Seems dumb to me. That's enough to make me not buy a Pete. Even Kenworth has it on the drivers side. Don't they want to sell trucks? I guess we're going to start seeing Petes going backwards through the fuel islands on a regular basis. Bad planning there.
  3. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,844
    Jul 28, 2011
    Glasco,Ks.
    Don't quote me on this, but as far as I know you can order them on either side, question is thou, the trucks your friends bought, did they order them, OR did they buy them "off the lot"?
    They may have been spec'ed for another customer and the deal fell though?
  4. DrtyDiesel
    DrtyDiesel Road Train Member
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    I see them all the time on truck paper both kw and Pete's have the def tank on either side.
    Like stated above, it depends who orders them. You can choose which side you want the tank on and I believe there's 3 different sizes of tanks you can choose from too.
    Ethan
  5. GAlanFink
    GAlanFink Medium Load Member
    334
    271
    May 8, 2012
    Bucks County, PA
    I guess, since I keep hearing warnings and postings on our PeopleNet about driver's putting DEF in the fuel tanks by accident, maybe Peterbilt is trying to give a driver a little time to think?
    Every DEF dispenser I've seen at a pump location is on the Driver's side. If you actually have to go in and pick up DEF, you might not accidentally pour it into a fuel tank. Sounds pretty smart, if you ask me.
    DrtyDiesel Thanks this.
  6. DrtyDiesel
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    Yup, id also rather buy 3 jugs of def from inside rather than pull through the fuel island backwards
    Ethan
    milskired Thanks this.
  7. rwdfinch50
    527
    595
    Nov 6, 2007
    Leesburg, Fl.
    The 379 was ordered special right down to the tires and paint. The 387 was ordered by his company, but I would assume they were never asked. I know in the case of the 379, it came as a total surprise to him. His older truck didn't have DEF, and he didn't even think about it until he bought the truck home and I asked him about it. Now he's trying to find a way to run a fill tube to the drivers side. He is an intelligent driver with over 40 years experience. I'm sure if they mentioned it to him, he would have opted for it on the drivers side. Now he has to run to pay for the truck, and he cannot just give it back. Had he known, he never would have accepted delivery on it. It's too late now. My friend with the 387 said he's just going to go backwards through the fuel lanes when he needs to fill it up. Seems crazy to me. It should be the same on all trucks.
  8. Winkjr
    Winkjr Road Train Member
    1,804
    614
    Oct 18, 2011
    Marlton NJ
    You know that hose stretches right?
  9. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    Mine is on the Drivers Side, but I have found if I accidentally pull up too far it barely reaches.
  10. rwdfinch50
    527
    595
    Nov 6, 2007
    Leesburg, Fl.
    No way it stretches that far
  11. rockhead
    rockhead Bobtail Member
    8
    Aug 16, 2012
    Our 389 has DEF tank on driver's side. I know that you can specify when ordering the truck which side to put it on. So its on the person doing the order
