Why won't drivers listen to the escort....
Discussion in 'Heavy Haul Trucking Forum' started by UnitedPCS, Oct 20, 2017.
  1. UnitedPCS
    UnitedPCS Bobtail Member
    4
    Oct 20, 2017
    Houston, TX
    I'm just curious about what other heavy haul drivers have to say about this.. and please don't take this the wrong way. As an escort, we are there to lead/chase/hp/steer you. That is our job. It just seems that alot of heavy haul drivers that have been doing this a while hate the idea of having an escort, much less an escort with so much responsibility with the load he is driving. Why can't all drivers just listen when we say "Hey I hit the power line" or "STOP! We're rubbing against this pole on this turn".. When they don't listen and there is an incident then everyone gets replaced on the load.. I just don't understand and wanted to get your insight on the situation..
  3. kylefitzy
    kylefitzy Road Train Member
    4,653
    19,270
    Aug 12, 2007
    Kansas city,Mo
    A good driver should listen to their pilot cars. That's what they're here to do. Be the eyes on the things we can't see. Before that truck moves an inch the one signal everyone needs to agree on is stop.
    Pilot cars dont run the show and most aren't worth a dang unfortunately. That's to be expected when some "escort company's" are paying pilots as little as 75 bucks a day.
    The ones I run with most split what the truck makes with the owner. Out of their half of the rate, they buy fuel and that's it. They are #### good pilots.
    If a pilot came over the radio and said "stop, your rubbing that pole" they have failed, and probably just cost everyone, including the driver their jobs. With what I haul the damage for clipping a pole starts at around 100k dollars. You should be creeping and possibly have a pilot on foot with a handheld if you're that close to something. You do have a handheld right?
  4. Gunner75
    Gunner75 Road Train Member
    5,701
    9,074
    Mar 17, 2014
    Jackson Center Ohio
    This should be interesting
    AModelCat, BigBob410, Oxbow and 3 others Thank this.
  5. aussiejosh
    aussiejosh Road Train Member
    4,709
    5,409
    Aug 28, 2009
    Airlie Beach QLd
    Yes the idea of a very good pilot would be usually to warn on coming traffic of the wide load and to prevent you from coming near any obstacles.
    MartinFromBC, kylefitzy and UnitedPCS Thank this.
  6. UnitedPCS
    4
    Oct 20, 2017
    Houston, TX
    Yes. 100% there was a pilot on foot with a handheld everytime. Heck, even on a highpole load, pilot was pulling over to get out and break out a line stick to raise the wire but driver threw a fit. Then all of a sudden, BOOM, fireworks in the sky while line bust apart. It just don't make sense. By no means am I saying that ANY pilot runs the show, but I would think that a driver should listen to them at all times. Me, personally, I only listen to the driver when it comes to authority. I know I'm not the best escort out here on the street by all means nor do I have the experience that alot of others do, but there's one thing I'm good at and that's learning and adapting.
    LWT104 Thanks this.
  7. TripleSix
    129,829
    @Ruthless, do me a favor and tell her your pilot car story. It seems that she has already gotten on my bad side, so I will back out of this thread.
    truckdad, SAR, cke and 3 others Thank this.
  8. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    Why is it that pilot cars have such a hard time listening? When I tell her to stay behind me, and I'm in the right lane, she should be in the right lane. If she sees traffic merging on ahead, she can ask if I'd like to move over. But I shouldn't look to my left and see my pilot car blocking the left lane and holding everyone up. And when I tell her to get back behind me, she should definitely not tell me that she's holding that lane in case I need it, after I've already decided that I don't need it, and refuse to get back behind me.
    That one won't be escorting me again, that's for sure.
  9. Rontonio
    Rontonio Road Train Member
    6,312
    46,042
    Aug 9, 2009
    There are many things I could say here...but mostly it is as the driver - I am responsible for the load and it’s safety.
    I pay the pilot car bill and Expect to get the service I ordered. So when I come and meet with you prior to starting out to go over what we can expect during the days trip, it would be ideal if the pilot could listen and ask any questions.
    I can’t count the number of times I have said “I run 55-60 and less when circumstances dictate” only to have the front car take off and end up a mile ahead of. Or mostly I have pilots for length, please know which side to protect when I am making a turn ...
    And it does know good to tell me I don’t have clearance after I hit something. If you think I am not going to clear it we have a super tight corner - tell me before we can’t undo it.
    I will listen to you as the pilot car but know when and what to tell - oh and be on time and not on half a tank of fuel or have no sign or radio or ..... yes all of those have happened to me while paying the bill.
  10. Ruthless
    Ruthless Road Train Member
    8,949
    88,147
    Aug 28, 2010
    The City.
    Communication is key. Both ways.
    If you, let's say, have a load routed a particular way, and halfway thru you come to a multi level bridge which you are routed on the bottom level because that's the only level that has a toll booth at the other end that will accommodate your size. And let's say the bottom level is closed for construction (this is 11:30pm on a single move, single date/time permit) and you take a chance going the upper level, which you've read all the other permits that you've gotten and mentally taken note that you're permitted about 1.5' wider than will fit.
    And let's say you squeak it through the booth while your front escort is screaming at your back escort to TALK MOTHER####ER LET THE DRIVER KNOW WHATS HAPPENING WHY ARE YOU ####ING SILENT
    while he stays silent.
    And let's say after you made it thru the widest booth on that level the rear escort suddenly comes back to life to say "well I didn't think you were going to make it"
    That's a lack of communication.
    Those were not cheap escorts.
    I appreciate professionalism.
    Know your job, do your job, be a professional. You'll have my respect.
    Show yourself to be an amateur: you will not have my respect.
  11. UnitedPCS
    4
    Oct 20, 2017
    Houston, TX
    If I offended you in any way, I sincerely apologize. This post is not to BASH the drivers. This post is just to help me understand what might be going through the typical od drivers head. Thats all.
    This kind of information is very helpful, just letting you know. Every driver is different just as every escort is different. I'm not going to lie about this, I am that escort you are talking about. But in saying that, if you tell me to stay in the right lane then I am going to stay in the right lane. Like I said before, I listen to driver for authority. I guess this is why I am still on the hunt for a full time driver. It would be alot easier to have the same driver because I will know what to expect every run.
    I agree that there are escorts out there that do not listen. Believe me, I run across them all the time out here on the road. And I agree that if you are going to be doing this job, then you need to know what side to protect no matter what load you are on. But about the "know when and what to tell", every driver is different. I mean, I escort blades at times and the driver doesn't want to know anything past the rumble strip unless it's a four/eightteen or in the zipper, but then sometimes you get a driver that wants to know anything on the fog line even if it's half way in the grass. Please understand that it is very confusing when going through drivers just as it is with you frustration while going through escorts.
    Very much a lack of communication. All that yelling and screaming on the radio while the load is on the move is unacceptable if you ask me. I'm suprised you didn't fire them and get some new ones in a jiffy.
