Why would a turbo make a loud sound
Discussion in 'Trucks [ Eighteen Wheelers ]' started by KenworthonTheRun, May 2, 2014.
  1. KenworthonTheRun
    KenworthonTheRun Bobtail Member
    16
    Sep 30, 2012
    East Coast
    Why would a turbo make a loud sound when pushing pedal down.
  3. KenworthonTheRun
    16
    Sep 30, 2012
    East Coast
    How can any one tell when an EGR goes bad
  4. KenworthonTheRun
    16
    Sep 30, 2012
    East Coast
    How many of you do know when a turbo goes bad and why?
  5. 201
    201 Road Train Member
    12,199
    24,894
    Apr 16, 2014
    high plains colorado
    Is the power down too? Loose connections at the turbo could cause more noise, but you'll notice a drop in power. If the bearings are going south, I think it will growl and not whistle. If the bearings go, the seals will too and it will leak oil. In any case, if the turbo let's go, it ain't pretty.
    gpsman and KenworthonTheRun Thank this.
  6. positiveone
    positiveone Light Load Member
    83
    41
    Aug 31, 2010
    North Augusta, SC
    It really depends on what failed in the turbo and what clamps and seals gave way.
    How can any one tell when an EGR goes bad?
    There are many different symptoms that can be given off if an EGR valve bites the dust.
    1. Loss of engine power (derate)
    2. Loss of or reduction in Jake Brake
    3. Huge amount of smoke coming out of the stack(s)
    4. Erratic idling. (RPM jumps up and down)
    There are probably plenty more that drivers/owners have experienced with a bad EGR valve
    There are a variety of things that can tell you when the turbo is bad or is on the way out. I have heard them whine when you get on the throttle, reduction in boost, and blown oil.
    I guess the easiest thing to do is tell us what problem are you having?
  7. justa_driver
    justa_driver Road Train Member
    1,105
    817
    Apr 2, 2014
    Tennessee
    Bearing going out in the turbo. Usually if its the turbo you will see dampness spots around the turbo but usually if its making a noise its going bad. One went out on me while I was going down I75, looked like a big fireball of smoke going down the road.
    KenworthonTheRun Thanks this.
  8. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    Depends on the sound. My old ISX cm870 would make a loud pop/cough sound when the egr was actting up. Its actually compressor stall that makes that sound.
  9. texasmorrell
    texasmorrell Medium Load Member
    597
    625
    May 3, 2012
    Lone Star State
    Most likely the bearing or the turbo mounting gasket. Feel around the base of the turbo where it mounts to the manifold. If you feel a sharp edge sticking out that is the blown gasket. If it is smooth then take off your air to air hose and look and feel inside of it. If there is oil or an oily residue, the turbo is shot, get it fixed fast. If you put off getting it fixed you are risking a runaway. Keep a big plastic garbage bag with you to use to choke the air intake if it happens. Its the only way to stop the engine once the runaway starts.
  10. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    If the end of the turbo is exposed, and if you have a bad bearing, you will be able to wiggle the end of the shaft up, down and sideways. if you have that wiggle, dont wait, get it serviced NOW!
  11. KenworthonTheRun
    16
    Sep 30, 2012
    East Coast
    Thank you for responding you alll
    a simple gasket can make a turbo make a loud sound while driving.
    There’s more info posted on my blog that i expressed egr, turbo and vpod.take a look at what i wrote.
    1.
    1 I wrote a an article in my blogrecently what happened to me and it was a bad thing a simple thing can cost you$10.000 go to my blog Please let me know.
    A mechanic screw up.
