Why you should idle your engine while doint a Pre or post trip inspection
Discussion in 'Experienced Truckers' Advice' started by striker, Dec 14, 2014.
  1. striker
    striker Road Train Member
    6,023
    6,439
    Aug 8, 2009
    Denver, Co
    This past Friday afternoon, my boss asked if I wanted to work on Sat, a quick local HHG delivery to a residence. Ok, I needed the money. So Sat. morning, I came in, checked my coolant and oil, thumped my tires, fired the truck up, let it warm for a few, hooked and booked.
    When I got to my customer and checked with the resident where they wanted me to park, I had the truck idling, I noticed a slightly odd sound, not really a "knocking", but more like an occasional "whack". After I was situated and unhooked and parked my tractor out of the way, I checked it over, couldn't find anything wrong.
    When I came back to the yard, I stopped at the gate, got out to enter the code, when I did, I could hear an intermittent "knock" from under the hood. Pulled in, dropped the empty out back, noticed the "knock" again. Pulled up to fuel, while I was fueling, the truck was idling, and I could still hear it intermittently. Opened the hood, looked around, didn't see anything. Just as I was flipping the hood release, something caught my eye. MY KNOCKING SOUND.
    The engine fan and belt pulley were wobbling on the hub. With the engine off you can't move them, but as soon as the engine is started, you can see them wobbling, and it's just enough to allow the fan and the pulley to occasionally hit something.
    Called the boss at home, he was not happy. SO now, my truck is sitting in the shop, will be a two to three day repair depending on the availability of parts from the dealer. I'll be stuck driving an underpowered older daycab in the mean time. Oh, and he just replaced these very same parts 7 months earlier.
    Just something to look for when doing your inspection.
    BTW, had I not caught this and it failed totally on the road, in addition to having it towed, based on this happening previously, it would have also taken out the fan, pulley, rad. tank, probably the rad., the belt and tensioner, fan shroud and also the fan wiring harness.
    Shaggy, 25(2)+2, TruckDuo and 5 others Thank this.
  3. 201
    201 Road Train Member
    12,621
    25,905
    Apr 16, 2014
    high plains colorado
    Hi striker, I hear ya', I ALWAYS idled the motor while checking it out. These bean counters telling you to shut your engine off to save a few pennies. Classic example of jumping over a dollar to get a dime. Unless it was being recorded, like my union job with electronic logs, required us to shut off the motor, but with my trucks, there's been several times, I noticed a loose belt, or something leaking when running, I say, Good job!
    Mr.X Thanks this.
  4. FLATBED
    FLATBED Road Train Member
    Striker did you not post that you were getting a new TRACTOR recently ?
  5. Vilhiem
    Vilhiem Road Train Member
    3,992
    10,904
    Oct 6, 2014
    Wow, yeah Schneider tells us not to idle. I had wondered about this myself because there is some stuff you can't see/hear without the engine running.
    Seems like it would pay to do the pretip while the engine is off and running too.
  6. Arielit0oo
    Arielit0oo Light Load Member
    187
    108
    Jul 6, 2014
    Tacoma, WA
    Yeah, Schnieder tells you not to idle because they don't want to pay for the fuel, even if it's almost nothing.
    Back OT: Good idea. Ill do this on my pre/post trips as well.
    Shaggy Thanks this.
  7. striker
    6,023
    6,439
    Aug 8, 2009
    Denver, Co
    Haven't gotten it yet, long, drawn out story. The truck has been here since Sept.., spent a month at the dealer getting stuff fixed, then two months in our shop while my boss was doing stuff to it, and fighting with the dealer over poor fitting fairings and paint. Now the truck is at the body shop to get the roof and side fairings repaired, repainted, installed correctly. If I'm lucky, maybe January.
    FLATBED Thanks this.
  8. FLATBED
    I hear you getting the same BS from KW dealer on an additional T680 I was looking to buy , but the hassle is getting the deal no where , is yours another MACK ?
  9. Numb
    Numb Crusty Curmudgeon
    4,224
    9,905
    Jan 30, 2012
    Charlotte, N.Carolina
    you can't air up the air bags in the tractor and the trailer or listen for air leaks if the truck is not running.
  10. Starboyjim
    Starboyjim Road Train Member
    2,039
    1,425
    Dec 10, 2011
    Weed, CA
    Good work, Striker.
  11. striker
    6,023
    6,439
    Aug 8, 2009
    Denver, Co
    Yep, that's all the boss will buy. Which is fine, we all like them, truthfully, we demo'd a Pete and a KW daycab two years ago vs. a new Mack daycab, the Mack had a roomier cab, was more comfortable, quieter. One of our competitors only buys KW and Pete, their senior driver in Denver took a ride around their yard in my 5 yr old sleeper, he's trying to convince them to buy him a Mack to replace his Pete that the engine grenaded on.
