1. D29N
    D29N Bobtail Member
    6
    Novi, Michigan
    Hello there everyone. Can anyone answer me as to why so many companies are requiring prospective drivers to be able to climb into a trailer from the ground...and has anyone ever actually had to do so?
    My friend is only 5' tall with an inseam of 28" and is having trouble getting past this requirement. She is considering perusing legal recourse.
    Thanks
  3. reptij
    reptij Medium Load Member
    401
    108
    Oct 3, 2011
    Rochester, NY
    Because it is a physical requirement to pass the DOT physical. If your friend cant do it then your friend cant do the job. Have fun suing the DOT for setting the physical requirements.
    The reason for being required to do this is so you can get into the trailer for securing loads, sanitation, and basic maintenance. If you cant climb into your trailer to properly secure a load then you legally cant do the job.
  4. D29N
    D29N Bobtail Member
    6
    Novi, Michigan
    It is NOT a DOT requirement. I have contacted the DOT and they allow the use of any "step" or "ladder" that is rated safe for your body weight for use to get into the back of a trailer.
  5. reptij
    401
    108
    Oct 3, 2011
    Rochester, NY
    Then tell your friend to buy a ladder!
  6. D29N
    D29N Bobtail Member
    6
    Novi, Michigan
    She has a step stool but the companies she has talked to will not allow her to use it. Hence my question here on the forum.
  7. lostNfound
    lostNfound Road Train Member
    3,506
    2,269
    Jun 28, 2007
    Home of the Stampede
    Got a link for that? I mean a link somewhere that confirms it is a DOT and not a company requirement?
  8. lostNfound
    3,506
    2,269
    Jun 28, 2007
    You should know by now that many large trucking companies are generally staffed by idiots. Especially, it seems, in safety departments. She should ask them why they do not allow the use of an aid when that is what the DOT recommends.
    As to whether anybody ever has to do this? Yes, many times per day sometimes.
    An alternative would be for her to seek out companies where it almost exclusively drop & hook.
  9. giants14701
    giants14701 Road Train Member
    1,439
    295
    Mar 29, 2010
    Jamestown,ny
    What companies is she talking to? Telll her to use the icc bar
  10. D29N
    D29N Bobtail Member
    6
    Novi, Michigan
    Medical Examination Report
    FOR COMMERCIAL DRIVER FITNESS DETERMINATION
    form: 649-F (6045)
    http://www.fmcsa.dot.gov/documents/forms/649f.pdf
    She has passed the DOT Physical at companies 3 times this year but can not climb into the back of a trailer from the ground.
    I have also spoken with 2 Doctors who perform DOT Physicals and she does pass and qualify the physical requirements as directed by the DOT.
  11. reptij
    401
    108
    Oct 3, 2011
    Rochester, NY
    No sorry I always thought it was, if it isnt...O well. If the company sets their own standards and make it a requirement and you cant do it then you dont get the job they are well within their legal rights and there isnt much you can do about it.
