Wide Based Tires
Discussion in 'Ask An Owner Operator' started by Gentlemanfarmer, Sep 20, 2015.
  1. Gentlemanfarmer
    Gentlemanfarmer Medium Load Member
    365
    384
    Feb 26, 2010
    Greenville, FL
    I have to replace my drive tires soon and was wondering if any of my fellow owner operators have switched over to wide based tires on both tractor and trailer. I have a Michelin account and have been encouraged by them to make the switch. They claim I would reduce overall weight by 1200 pounds, plus save fuel. They are offering $700 cash back if I make the switch. The other selling point is that Loves is stocking the X One in large quantities for quick turn around on road calls.
    I haul flatbed and have seen some of the larger flatbed companies using these tires, but have no idea how they perform. The down side is that if you have a blowout, you are dead on the side of the road, but then again, I haven't seen anyone limping to the tire shop with a duel missing, either. The other thing I would like to know is how they handle in bad weather, how the truck drives and handles and how many miles are expected out of the tires. I currently have 300,000 miles on my Bridgestone drives.
  3. Scooter Jones
    Scooter Jones Road Train Member
    9,551
    19,977
    Apr 19, 2011
    I bought my rig in June with duels on it. Swapped them out for super singles in August.
    I think the 1200 lb reduction is a stretch. Maybe several hundred lbs. I've driven company trucks with supers on them for the previous 5 years and never had any issues with traction, never had one flat either.
    I like the ride better and my fuel economy increased by 5%.
    PE_T and Gentlemanfarmer Thank this.
  4. DUNE-T
    DUNE-T Road Train Member
    7,035
    17,113
    May 10, 2015
    Detroit, MI
    I have 3 xdn2 with like 80% thread, and 3 other wheels with 20% thread, so total of 6 wheels, willing to switch for a set of decent duals.
  5. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    Do you have hub piloted rums.? Consider an tire sensing inflation sensor system, so you will know when a tire is loosing air. Consider carrying a spare that is mounted on a steel wheel. That way if you have problems, you are not at the mercy of the road service for an expensive rim and tire. It takes away some of the weight savings.
    Gentlemanfarmer Thanks this.
  6. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    500 lbs replacing 8 aluminum duals with 4 aluminum wide singles
    700 lbs replacing 8 steel duals
    so 1200 is reasonable if you have only aluminum outers or only aluminum drives.
    If you choose the right tires. But at $2/gal, this would not pay for itself soon.
    depends on tire choice
    generally better unless on a road rutted from duals
    depends on the tire you choose. The exception is if you drive fast (70+) the centers tend to wear
    sshewins and blairandgretchen Thank this.
  7. supersnackbar
    20,033
    52,182
    Aug 19, 2007
    Your Town, USA
    I am not an O/O, but the company I drive for uses them on their tractors. The one thing we have had with blowouts (which have rarely happened) is when a super single blows, it usually ruins the rim as well since there isn't a 2nd tire to support the weight until you get to the shoulder like with duals. They have decided to leave the tractors with singles, but switch the trailers to duals, which really makes it handle funny because our singles are on trucks spec'd for duals and the tires sit farther under the trailer then they're suppose to. Which makes them track funny in roads that have ruts from duals.
    As far as traction, in rain ours suck. I have had to lock my diff's trying to leave a truck stop with a light load just to get over an overpass. If you get off road in a sandy lot, be very careful, I live in a rural area with dirt roads and have gotten stuck in my own driveway several times. In winter, even without chains, I haven't had any issues with traction(to my surprise).
    As far as MPG, I can't say. I came from a previous company that ran the same truck with duals as I have now with singles...but they ran 62 mph where this company runs 68.
  8. Gentlemanfarmer
    365
    384
    Feb 26, 2010
    Greenville, FL
    Thanks for the serious replies so far. The tires I am looking at are the Michelin X One. Supersnackbar, I am surprised you get stuck with them. I thought that with a wider surface area, one would be less prone to get stuck, especially in sand.
  9. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    My previous employer switched to super singles on the trailer, and it saved 600 pounds. Therefore, switching tractor and trailer should save around 1200 pounds. However, I didn't like the way the trailer handled. Anytime the road was less than dry (rain, snow, ice) the trailer would dive for the ditch anytime the brakes were applied when I was empty. It wasn't as bad loaded, but it is still something to watch for. They don't cut into anything, they just float on top.
  10. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    I have seen driver have to get 2 new tires and 2 new rims just from simply hitting a curb with a broken edge. I have limped into a tire shop on one tire. The inside cap came off and if you got it over 50 it would shake the hell out of the truck. Luckily I was empty at the time.
    KB3MMX Thanks this.
  11. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    X-one is the name of the entire Michelin wide single line-up.
    XDN2: full tread, open shoulder drive tire -- probably the same traction/life you're used to and not likely to improve fuel economy.
    line energy D: closed shoulder, tight-packed, shallow tread drive tire. Best fuel economy, worse traction, worse life.
    line energy T: shallow tread, fuel efficient trailer tire
    XTE: Higher rolling resistance trailer tire that better stands up to scrubbing (better life on a spread axle)
    XZU: On road all position
    XZY: on/off road all position
    They are actually about 4" narrower than 2 tires:
    275 + 275 = 550mm whereas a wide single is typically 445 or 455mm. That's why some states & provinces limit their weight to ~8,750 lb instead of 10,000
    The "problem" with wide singles is in deep rain, mud, snow, etc. Slop at the center of the tire has to go 9 inches to reach the outside of the tire. Slop in the center of a dual tire only has to go ~5 inches. This kind of creates a snowshoe effect.
    Terry270, MrEd, Derailed and 2 others Thank this.
