Wierd electrical issue
Discussion in 'Freightliner Forum' started by 2fuzy, Jun 6, 2015.
  1. 2fuzy
    2fuzy Road Train Member
    1,053
    324
    Jun 19, 2008
    Granite Canon,WY
    I am having a wiring proplem and am hoping I am not the first
    2001 freightliner classic with a det s60
    Temp gouge goes off a random intervals also turns on the oil and temp warning lights and at the same time it started with the abs light for the tractor staying on and the abs light is somehow tied in with the fan splendid abs light on fan behaves normal abs light goes out fan comes on
    I am being driven nuts with this
    Things tried so far temp senders replaced no change
    Vigil bar replaced no change cm replaced no change
    After all this was out hauling oil down a rough washboard road and every problem except the abs light being on constantly went away for 6 months now it is back to being haunted
  3. Shaggy76
    Shaggy76 Heavy Load Member
    831
    307
    Feb 22, 2012
    Orlando, FL
    Sounds like a grounding issue that needs to be resolved. That will take a lot of time and patience to figure out.
    I would get the electrical manual and start with the ground distribution first.
    201 Thanks this.
  4. 201
    201 Road Train Member
    12,669
    26,048
    Apr 16, 2014
    high plains colorado
    Hi Shaggy, I agree, bad grounds do funky things to trucks. If it doesn't ground in the normal place, it finds other places, causing problems. I'd run another ground wire from the frame to somewhere clean on the cab, for starters.
