My truck is a 2000 VN770 with a DDEC IV 12.7L.
Has inactive code I cannot find anywhere.
MID 128 SID 051 FMI 3 (inactive 13 times)
Text fault says- Engine Aux output driver3 Electrical Fault.
No idea what that means. No CELs truck runs fine.
Wierd fault I can't find anywhere on the internet
Discussion in 'Volvo Forum' started by Amram, Dec 22, 2019.
I know it's an engine code. Just not correlating to anything I can find.
Connection to stage 3 engine brake solenoid is bad.
Possible places:
Bad connection inside ECM
Bad connections from ECM to wire harness.
Bad wire harness ( broken wire)
Bad wire harness under valve cover.
Bad connection to the solenoid.
Bad solenoid.
Looks like somewhere connection got loose and when engine vibrate it's throwing codes. -
I just had the overhead ran on it a few days ago. Took it in for weak Jake's.
Sounds like every other Volvo to me. I hate the weak Jake brake on Volvos, D13 at least.
Anyway, looks like Snail found it for you. -
Gotta love the electronics that Engineers today put in between you and "it."
My daughter has a 2915 Ford Flex.
Wouldn't steer.
So again, in between the wheel and the rack, they put an electronic controller, and a motor.
For what???
Hydraulics and pumps and lines aren't Techie enough for you?
They never fail.
This Flex was 4-5 years old and total steering crap out.Snailexpress Thanks this. -
This engine isn't a Volvo. It's a Detroit series 60
