will a toe in problem cause a bounce
Discussion in 'Trucks [ Eighteen Wheelers ]' started by earthmover, Dec 6, 2013.
  1. earthmover
    earthmover Medium Load Member
    563
    20
    Jan 27, 2009
    castalia , north carolina
    1997 fld freightliner dump truck my tires are wearing on the outside and I have a bounce at about 30 /40 mph then it seems to go away..i have the 425/65/22.5 on the front and don't need to mess my tires up....anybody know of a good shop to do a alignment around Raleigh nc ???I plan to have all 3 axles done ..whats a good price.....the inside seems to be wearing just fine outside looks like its cupping and wearing ....
  3. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Not likely. More likely worn shocks, out of balance wheel or drum. Mismounting is a possibility too.
  4. snowwy
    snowwy Road Train Member
    20,535
    13,271
    Jul 6, 2009
    yes.
    the outside will wear imto a roller coaster.
    i had a 05 w9 that did just that, and vibrated and the same speeds.
    i also had bad kingpins.
  5. grump
    grump Light Load Member
    74
    29
    Jan 1, 2011
    PA
    I have ran them for 22 years and seems they all do it to some extent some way worse than others , I had a wheel crack a few months ago and the new valve stem is machined in the face of wheel im sure yours is on the inside but I put centermatics on mine since I can now that valve stem is not in the way if it was me I would align it check all front end parts then leave tires on the same position and flip them on the rim , I know some of the super singles are out of round a friend of mine had them surfaced on the truck to make them round again sorta give them a hair cut is what the shop told him but he said after that was done they was smooth as glass till they were wore out ,hope this helps also they make different powder and bead balancing products personally they help but some times not .
  6. earthmover
    563
    20
    Jan 27, 2009
    yes I do have them swapped from side to side but man 900 each is bad.. I want this thing fixed..when I got the truck I didn't have this problem but now I will admit I never had it aligned ....and I just had the back stabilizer bars rebushed and plan to do the walking beams and have the frontend rebuild and then do a alignment cause the bounce is just out of control when loaded..like riding on a horse...
  7. grump
    74
    29
    Jan 1, 2011
    PA
    I hear ya on the price I just bought 2 bfgoodrich for mine 755 a piece mounted what kind are you running?
  8. earthmover
    563
    20
    Jan 27, 2009
    toyo tires... I had 2 wheels crack and replaced them but I never really did a lot of to the front end I had the spring hangers and bushing replaced last year with the bronze bushing and I keep everything greased at lease every other week.. but I guess the king pins can still good out.. had them replaced about 7 yrs ago and I know a dump is hard on parts in and out of all kinda places....I replaced all the shocks on the truck early this year front and back...ill take it somewhere and have the alignment checked and the parts and go from there cause I really need this truck to ride better then it does like before... its really hard on you now .......how could I check the leaf springs????? also if someone has had a 6 wheel alignment whats the going rate?????
  9. snowwy
    20,535
    13,271
    Jul 6, 2009
    the leaf springs won't do anything for you. unless they are sagging. shocks are what control the bounce. leaf springs. just look at them. see if they're cracked. all they are, is suspension. keeping the frame off the other parts.
    you'd have to find out the ride height specs to measure the springs for wear. worn springs will cause the truck to sit lower. but that's not anywhere near an issue as shocks.
  10. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    For the record toe in is very easy to check and two people can do it. Spec is 1/32 to 3/32. Measure from the middle rib of one tire to the other middle rib. The difference between the two measurements is your toe in or out. Sounds like you may have some toe out if the outside of your tires are wearing.
    04 LowMax Thanks this.
  11. grump
    74
    29
    Jan 1, 2011
    PA
    I would say most of your trouble is those tires I bough one set and never again bout shook the hood off I was able to run them out on lift axle , I bought them cause price was rite but paid out more in the end !
