will be on my own next week
Discussion in 'Questions From New Drivers' started by abishere, Jan 15, 2012.
  1. abishere
    abishere Bobtail Member
    louisville, ky
    I have read other threads, about my concern. I just got done with training, but during my training we was doing UPS and the loads were never that heavy. my trainer belittles people so i dont ask him for anything.
    My question is, when i'm at my heaviest i think its 45,000 in my trailer and i'm coming up to a 5% grade sign, what gear should i look to be in before i start down? I mean do drivers slow down to 35mph on a 65mph interstate before heading down, or even slower? i'll be driving 2006ish volvo's , this might sound stupid but just seems thats impeding traffic way to much or is that just what i have to do. also this question is for when coming up to a downhill and not after climbing a hill, because i understand that if i climb a hill in 4th or 5th then i need to be a gear lower on the way down. Thanks for anyones help, this i believe is my only worry cause i dont wanna kill anyone or my self
  3. Colorato
    Colorato Road Train Member
    1,336
    865
    Feb 22, 2011
    The first couple of times you'll need to go slower than you might want to. If you think I outta be in 8th go to 7th, set the jake (unless it's snowing), turn off the CB and take your time. Now one can tell you to be in this gear and this time. The conditions play a major role. Just do it in your time, your way.
    Rule #1 for any new driver: Don't worry so much about what other drivers say.
    Keithdabarber Thanks this.
  4. Gizmo_Man
    Gizmo_Man Road Train Member
    1,226
    599
    Aug 15, 2011
    Hardly around
    You go down any mountain in one gear LOWER then what you used to climb up it. If the truck has an engine brake (jake brake), make sure that is turned on as well. Use proper braking technique as well.
    Your first few times going down any mountain, you will most likely have the a/c turned on and the windows rolled down. It is normal to be a bit nervous.
    what gear you would use to climb a mountain? I cannot tell you, that is something you will have to learn from the seat of your pants. You DO NOT want to lug that engine down to a point of stalling.
  5. kidsdad
    kidsdad Medium Load Member
    327
    298
    Nov 11, 2010
    central illinois
    you need to be slowed down before you start down, or you won't be able to get down to the gear you need to be in. Don't worry about anybody else, just get in the granny lane. Other trucks will be slowing down also, just make sure you turn on your hazards, and slow down to where your comfortable. Over time youll learn how fast you can desend in any givin situation. Just remember, you can go down too slow as many times as you want or you can go down too fast once.
    b
  6. andy
    andy Light Load Member
    213
    72
    Oct 16, 2010
    MT
    Don't worry about traffic behind you. EVER.
  7. Allow Me.
    10,660
    12,168
    May 28, 2009
    Rancho Mirage, Ca.
    The first few times you start a descend, better to stop at the top, if allowed, and do a walk around and kind of take a short break. When starting a descend on an un-familiar downgrade, NEVER just top it and start down full speed.
  8. thehornet
    thehornet Medium Load Member
    333
    75
    Dec 26, 2011
    3 doors down
    great question and great advice,, when approaching a steep downgrade, look for signs indicating length and grade, also for truck run off ramps, shift into lower gear, {the same gear or a gear lower than you went up in} and use snub breaking all the way down, look for end of reduce gear signs than proceed to the posted speed limits.
    like Allow Me said, here in pa. there are posted signs for a driver to actually pull over before going down..
    best of luck..
  9. sharp.dressed.man
    sharp.dressed.man Heavy Load Member
    701
    507
    Dec 10, 2011
    IL
    The DMV manual says at least one gear lower than what you climbed in and also that you should determine a safe speed then brake until you are 5 miles below your safe speed let it come back up to safe speed and repeat.
  10. ultraclassic
    ultraclassic Light Load Member
    205
    71
    Aug 4, 2011
    Oklahoma City, OK
    Just like the guy training me just told me.. Don't EVER let anyone 4 wheeler or big truck dictate to you what's safe. If you feel safer going 15mph under the limit then do 15 under the limit you'll usually only get it wrong ONCE. Don't be harassed into going faster. He said a lot a quotes already posted above.
    I love this forum, for us new guys it is a gold mine of information and advice.
  11. pilottravel2002
    pilottravel2002 Medium Load Member
    688
    156
    May 25, 2011
    Tucson,az
    Just take your time and turn ur cb off,dont be listenen those ### holes behing u,and use a confortable low gear and set ur jake brakes on and do not shift just stay on the same gear and enjoy ur ride,any more questions let me know i can help u,no problem.☺
