Will High Power Radio Affect the APU
Discussion in 'Ask An Owner Operator' started by Houston_Driver311, Jan 1, 2023.
  1. Houston_Driver311
    Houston_Driver311 Bobtail Member
    23
    11
    Aug 2, 2015
    My truck is paid so if I mess it up it on me, but anyhow If I stick a high power radio in there (400) wats out it'll do 600 on a bird meter, but I don't use it over 400. I have a Thermo King Diesel APU in great shape. Will that radio have any affect on the APU. Just wondering, and as a disclaimer please if you don't really know just don't answer. If you actually do know and are not guessing please answer. Thanks in advance.
  3. Siinman
    Siinman Road Train Member
    5,351
    13,601
    Mar 5, 2017
    Kansas City, MO.
    Why would it mess with the Thermo King APU? You will only be pulling more power from battery so it may turn on more but should have no issue with APU. Unless you are trying to hook it up different?????
    Houston_Driver311 Thanks this.
  4. 062
    062 Road Train Member
    6,234
    33,567
    Oct 20, 2013
    If the antenna system and install are 100%,then no it shouldn’t. RF is similar to horsepower in that you’ll find the weak link.
    @jessejamesdallas
  5. onetime42
    onetime42 Light Load Member
    172
    114
    May 20, 2009
    Mobile, AL
    Will you be running just the APU while parked and listening to your stereo at a higher than normal volume? If that's so, my only concern would be the little alternator in your apu trying to keep your batteries charged. Otherwise it will have no affect on your apu.
  6. Ridgeline
    22,475
    117,982
    Well first what is the difference between 400 regular watts and 600 Bird Watts (sorry that's too funny)?
    Second if you have a crap setup (not the radio but the coax and antenna) you MAY have issues with not just the APU controller but also the truck computer(s).
    The important thing is to build the right BALANCED antenna system, this means the grounds (RF) need to be there, and matching the antenna system (this is the BALANCED part).
    Once you have the energy from the radio going to the antenna radiator and not feeding back through the coax, then you won't mess with the APU.
    jdchet and Siinman Thank this.
  7. lester
    2,920
    7,890
    Jan 2, 2012
    NW, Iowa
    Pretty sure he's talking about a CB radio, not a stereo system
    Tb0n3, Siinman and Houston_Driver311 Thank this.
  8. OscarGoldman
    OscarGoldman Light Load Member
    264
    534
    May 9, 2022
    I would use a Flux Capacitor so you don't exceed 88 Jigawatts.
  9. Houston_Driver311
    23
    11
    Aug 2, 2015
    No hooking it up to battery. Just asking incase there is some unforseen issue that could apply, or few people had issues or whatever. Just covering bases before I do it.
    Siinman Thanks this.
  10. Houston_Driver311
    23
    11
    Aug 2, 2015
    I only work local so my APU Is basically used to charge batteries. And I'll turn it on 30 mins or so once every 2 weeks or so to let it just run, and keep everything greased up.
  11. Houston_Driver311
    23
    11
    Aug 2, 2015
    Thanks everyone for the replies. I pretty much figured it wouldn't affect it just wanted confirmation before install.
