Will my battery die if I leave my mini fridge plugged in on a 10?
Discussion in 'Questions From New Drivers' started by xzmpt, May 20, 2024.
  1. xzmpt
    xzmpt Light Load Member
    91
    82
    Nov 22, 2022
    Just got a new mini fridge. I’m about to take my 10 and I have food in it so I can’t unplug it. Will it deplete my battery?
  3. Big Road Skateboard
    6,651
    37,331
    May 2, 2021
    It shouldn't, but it depends on the fridge and your batteries. You'll know in 10
  4. DUNE-T
    DUNE-T Road Train Member
    7,014
    17,069
    May 10, 2015
    Detroit, MI
    I leave my on every night and it never dies unless it's more than 48 hours and it's above 75 degrees outside
    wifi_guru, flood and xzmpt Thank this.
  5. Arctic_fox
    4,350
    23,440
    Sep 16, 2016
    Depends on the batterys, the fridge, anything else that may be drawing power ect. A big studio fridge when its 80 or 90 degrees out on 2 worn batterys? Yea that would likely die.
    A little truck fridge on 4 brand new batterys at 60 or 70 degrees? That will likely be fine. That same setup but you have a bunch of parisitic power draws? Maybe it will die.
    Best way to check, is see what if anything your truck is pulling from the batterys when turned off and fridge off with a multimeter. Crank the heat up in your truck to like 80 before you check so the fridge works hard and turn on the fridge. See how much its pulling then compared to how much battery power you got and crunch the numbers. Or you can just have a jump starter handy and leave it overnight turned off but fridge running. Worst case just jump it in the morning.
    As a general rule though most batterys in good condition can support a small fridge for a 10 hour no issue.
    xzmpt Thanks this.
  6. MacLean
    MacLean Road Train Member
    1,357
    4,003
    Sep 12, 2017
    If it does you have bad batteries. Do you have a battery protection device that will kick everything off if the voltage drops?
  7. wifi_guru
    wifi_guru Medium Load Member
    352
    318
    Feb 22, 2024
    why would you want to keep food in the fridge for 10 days it would more than likely go bad in that time hell eat it while your on your 10 and replace it with new just unplug the fridge to save on the batteries
  8. Deere hunter
    2,118
    9,986
    Aug 5, 2017
    Shallowater Texas
    I'm good for three day's at least,unless batteries are weak.
    wifi_guru Thanks this.
  9. Magoo1968
    Magoo1968 Road Train Member
    2,050
    5,465
    Mar 18, 2021
    St Malo mb
    Depends is youre batter wearing winter clothes in the fridge
    pavrom and wifi_guru Thank this.
  10. wifi_guru
    352
    318
    Feb 22, 2024
    Depending on the truck your in it should have an opti idle feature to heat cool and charge the batteries also
  11. Moosetek13
    Moosetek13 Road Train Member
    14,812
    18,698
    Nov 1, 2010
    Burnsville, MN
    10 hour break, not 10 days.
    wifi_guru and Crude Truckin' Thank this.
