Im taking my skills test Thursday and was told by my company that I would drive the truck and trailer that I will be operating to take my skills test. I just happen to look at my trailer and truck today to assure its GVWR was sufficient for the test. The truck GVW 13,200 and the trailer GVW 12,000 so its not 26,000. I'm asking because I keep reading the Manual and its a little confusing. I would think if the trailer's GVW is more than 10,000 then one would need a CDL.
Thanks for everything
Keep on Trucking
Will my GVWR work for a Class A skills test?
Discussion in 'Questions From New Drivers' started by jessedavis82, Mar 18, 2014.
Page 1 of 3
Need more info. What type truck is this ? And trailer ? Air brakes ?
What state are you in?
Your going to get the air brake restriction using that setup, which means if you ever want a real class A (for big rigs) you will have to take it again. Since you already need a class A driver to accompany you to the test I would find a truck with air brakes so you only have to test once.
Jokingypsy Thanks this. -
Chevrolet 3500 dually
trailer is a Flat bed with a hydrovac/high pressure spayer setup Vac-Tron is the manufacturer. We use these in the pipeline construction business. We use high pressure water then suck up the mud to create a pothole to expose crossing pipelines.
I looked at the trailer metal tag (vin,GVW, etc.) and it says GVW 12k and the manual to hydrovac says it as well.
I looked on the driver's door of the Chevy and it says GVW 13200
The trailer does not have air brakes.
Im in Texas -
No, that setup would not qualify you for a class A, the "combination needs to exceed 26,000#, and yours does not.
https://www.txdps.state.tx.us/DriverLicense/dlClasses.htm -
Hey Truckon,
I thought the rule was a trailer for commercial use over 10,000 GVWR you needed a class A. I thought the only exception to this were not for hire rigs, pulling there own boats or rv's? I'm 99 percent sure he will need a class A for his rig. Anyone else care to add onto this?
Adam -
I provided the link before. -
I just went through this in Texas 2 years ago. 26,001 or larger for the test.
Page 1 of 3
