will not accelerate when rolling
Discussion in 'Peterbilt Forum' started by semi, May 8, 2013.
  1. semi
    semi Bobtail Member
    Hi I own a 2000 379 with cumins n14 select + its been in three diferent shops they can't fix it it throtles just fine when parked but when starts rolling it will not accelerate.We've changed the ECM and TPS
  3. jameslawton
    jameslawton Light Load Member
    257
    65
    May 1, 2013
    Tulsa OK
    check for a pto switch that is turned on even if truck dont have pto there are wires behind the dash for one
    also if you roll fast enough will the cruse speed up the truck or just nothing
  4. jameslawton
    257
    65
    May 1, 2013
    Tulsa OK
    is your speedo reading right a loose yoke nut or bad vss might cause a derate will it rev up at all or act like no tps responce
    do you have computer there you can check on the tps sencor there is a off idle switch if its not showing thats its moving it wont let it rev can be bad wire to ecm
  5. Dryver
    Dryver Road Train Member
    2,818
    2,575
    Nov 30, 2008
    Sioux Falls, SD
    When trying to accelerate under load are you getting black sooty smoke out the pipes?
  6. Lone Ranger 13
    Lone Ranger 13 Road Train Member
    1,542
    1,298
    Sep 27, 2012
    Asheville, NC
    Had this problem on my 2003 C-15 ... Sometimes it would idle but you step on fuel and it would just idle. Sometimes it would start behaving this way with no warning. The cure: my truck uses regular metal spin on fuel filters. I must use one that has a separate rubber o-ring for the filter that is mounted on the frame. If I use a filter with a built in o-ring it may or may not function properly. Even though I have a Cat, I have had mechanics tell me my frame mouned filter mount is for a cummins. I use a fleetguard FS 1000 and never have a problem.
  7. Lone Ranger 13
    1,542
    1,298
    Sep 27, 2012
    Asheville, NC
    And I mean the rubber o-ring that is maybe 1.5" in diameter that you slide up the pipe that u thread your filter onto.
