Will someone explain the AC controls on the international to me.
Discussion in 'Questions From New Drivers' started by TawcoTruck, Apr 24, 2023.
  1. TawcoTruck
    TawcoTruck Light Load Member
    155
    224
    Dec 11, 2022
    What do the dash marks in-between each setting indicate? What does "max" on the dial turned all the way left do? What's the difference between the defrost setting on the dial and the max defrost button?
  3. JC1971
    JC1971 Road Train Member
    2,673
    9,784
    Jul 29, 2013
    Southwestern U.S.
    The MAX setting just makes the fan blow faster I believe and therefore provides more cooling and more windshield defrosting.
    77fib77 Thanks this.
  4. tscottme
    tscottme Road Train Member
    On many vehicles Max A/C is just high fan speed plus Recirculate. Recirculate is when outside air is no longer used and the HVAC just takes the air in the cab and conditions it. Max Defrost also closes the "fresh air" inlet and just dries the air already inside the vehicile. Recirculate should only be used for brief periods. Otherwise it just causes you to sit in stale air while you have the normal stresses of driving.
    Bean Jr. Thanks this.
  5. flood
    flood Road Train Member
    4,163
    4,035
    Dec 25, 2010
    The difference between "max ac" and "defrost"
    max ac is it runs the ac contest in recirculation and dash vents only
    Defrost runs the ac intermittently to dry the air and only thru the windshield vents.
    The dashes between are 1/2 steps between the pitcher....straight up pic is vent blowing at your face next pic to the right is blowing at the floor.. the dash between is face AND floor
  6. TawcoTruck
    155
    224
    Dec 11, 2022
    There is face, then a dash mark, then face+ floor. The pictures make sense, but the little tick mark in-between doesn't.
    Gridaxe5588 Thanks this.
  7. flood
    4,163
    4,035
    Dec 25, 2010
    straight up (on mine) is face then left is dash (face+floor NO AC) then face+floor WITH AC..
  8. tscottme
    I think I understand the tick marks you are talking about. One position shows vents toward the face. There is a tick and then a position that represents vent to the floor and the face (let's say 50% face / 50% floor), a tick, and position that vents to the floor.
    I propose the tick mark between "face and floor" and face is the position where most of the air is vented toward your face and some is vented toward the floor. The tick between "floor and face" and "floor" is where most of the air is vented toward the floor and some toward the face vents.
    rockeee Thanks this.
  9. Powder Joints
    7,720
    7,850
    Sep 25, 2007
    Rosamond, SoCal
    Roll the windows down. letter rip potatoe chip. 60X2
    lester Thanks this.
  10. Numb
    Numb Crusty Curmudgeon
    4,111
    9,528
    Jan 30, 2012
    Charlotte, N.Carolina
  11. SoulScream84
    3,426
    26,076
    Mar 21, 2020
    Wow....
    New "drivers" not only can't back or shift, now they can't operate the thermostat?
    Snailexpress and Numb Thank this.
