WILSON 2000 trucker
Discussion in 'CB Radio Forum' started by brianharrison, Jan 19, 2011.
  1. brianharrison
    brianharrison Bobtail Member
    49
    9
    Dec 5, 2010
    st augustine,fl
    im running a wilson 2000 antenna and have it mounted through the roof of my gmc pickup, my swr readings are too high and ive moved the whip up and down and no matter what i do i can only get my swr down to 3 .0,and do i need to ground it?
  3. Carolina Thunder
    Carolina Thunder Medium Load Member
    584
    179
    Jan 28, 2007
    Coeburn V.A.
    At least an 8 gauge wire from the antenna mount to the frame. If your using a mag mount then your mag is not pulling enough ground from the body of your truck and you need to go to a bigger mag mount.
  4. handlebar
    handlebar Heavy Load Member
    Brian,
    Is there any chance that the hot part of your mount (the 3/8x24 where your antenna threads into the base) is shorted to ground? If you've got an ohmmeter, set it for ohms and put one lead on the hot, and the other lead to ground (like the sheet metal of the roof). Alternatively, just unscrew the coax connector from the radio and read between the center pin and the shell. If you show essentially *any* numbers, or all zeroes, your system is shorted, and no amount of adjusting of the antenna's length will fix it.
    3 checks to do on any coax after an installation:
    1) Center pin to shell: should show infinite resistance, meaning not connected to one another;
    2) Center pin on plug to the hot part of the mount, where the whip screws in: should show 0 ohms or very close to it;
    3) Outer shell of coax plug to ground, ideally at the mount: should show 0 ohms, or very close to it
    If any of these three conditions are not met, you already have an antenna feed system fault, and need to fix it before you go any further.
    When I do an install, I always do these checks *before* I install the connector on the "radio end" of the coax. That way, if I've got a braid strand shorting at the mount, or a pinched coax going through a body panel or someplace, I can fix it right then. If I waited until after I'd put on the PL-259 connector, I wouldn't be able to tell where the fault was (sometimes plug installations go awry).
    All this assumes that your GMC pickup's roof is metal; if it's some sorta Jimmy or something with a plastic roof, you'll have to change antennas or install ground plane foil on the underside of the roof.
    Hope that helps,
    -- Handlebar in NC --
  5. Carolina Thunder
    584
    179
    Jan 28, 2007
    Coeburn V.A.
    Statesville NC? Im an Ex Alexander county boy myself. You run a base at home? May have talked to you at some point.
  6. handlebar
    Yuppers, and don't think so, in that order, unless you're also on 2M or 75M.
    I only moved here about a year ago, and have only a modest antenna up at the homestead.
    I only know of Alexander County cuz their jail had an escapee two days ago, and a horde of police officers caught him in the woods half-a-mile from the house after a 4-hour search with doggies.
    Clearly, I've gotta get out more :) And spend more time with a map :(
    Just in case, though, I use Handlebar as my -- excuse the term -- handle, mostly on 19 & 22.
    73,
    -- Han.... ah, you already know ;) --
  7. handlebar
    I only know of Alexander County cuz their jail had an escape two days ago, and a horde of police officers caught the miscreant lad in the woods a half-mile from the house after a 4-hour search with doggies.
    73,
