found a antenna but it says STINGER is missing.....what part of antenna is stinger?
can it be replaced or isnt worth the hassel?
magnet mount wilson 5000....says its missing from box (stinger)...$52 asking bid
plus...whats difference from 1000 to wil 5000....whip lenght or/and base of antenna?(not magnet)....coil thicker,bigger or are they exactly alike and whip is longer?
txs all...
wilson 5000 stinger?
Discussion in 'CB Radio Forum' started by aircargoo, Jun 1, 2009.
The stinger is the whip, or the metal wire that stands straight up out of the base of the antenna.
Yes you can replace the whip. I actually have a spare sitting I got when I bought my 1000 used around in case I ever find another Wilson 1000/5000 w/o the whip, as most are afraid to ship them with the whip thinking the cost to ship would be expensive.
The difference between a 1000 and a 5000 is the 5000 has an extra heavy duty coil for running a lot of power thru. The Wilson 1000 will handle 3000 watts max. The 5000 will handle an extra 2000 watts and 20k watts on ssb. -
yea....was reading about power.
theres a 1000 4sale without whip on ebay.....might be over thou. was at about $52 2 days ago.
not worth the hassel...give it another week or so ill get it new maybe.
You can get a new W/2K for $60 or less
For what it's worth...I would Never buy a "Used" Wilson Antenna off eBay or any where else...Reason being, you could be buying one that has problems with the coil, and the guy is just trying to unload it on some poor individual to get some of his money back...
I have had several Wilson's that after a while developed shorts in the Base, which is where the Coil is...They look OK, but will have a rattle when you shake it...And they will not tune...
