Wind ratings for end dump trailers?
Discussion in 'Experienced Truckers' Advice' started by DW316, Apr 6, 2017.
  1. DW316
    DW316 Bobtail Member
    My company has me running today hauling sand to a concrete company in Charleston, SC.
    We've got a wind advisory here for 30-35 mph wind with gusts up to 40 mph til 8pm.
    I can't find a wind speed rating anywhere for ANY trailers.. even the owners manuals just say not too lift in "excessive wind".
    What is excessive? 10 mph? 40? 80?
    I have a frameless macsimizer trailer and dont know if I should even bother.
  3. DW316
    Should also mention I can't change the angle I dump at to face the wind, we dump between two short walls into grates in the ground
  4. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    Well, measure the wind as you're dumping. When you're blown over make a note of the wind gust speed ... that will be your "wind rating" max
    Every situation will be different, especially in terms of wind direction relative to truck orientation. I used to run end dump trailers and in my experience I would not worry too much until wind gusts reached about 40 MPH. I'd be sure to leave the tarp rolled over to keep gusts from entering the trailer hull.
    Bean Jr., Ruthless, LoneCowboy and 2 others Thank this.
  5. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    You are getting a little deep here. This is not Aviation.
    It is a nice little tidbit to know what your trailer will take. But consider the following. When under a Issued official high wind warning (Advisory depending) most high profile vehicles are impacts. I cannot imagine a higher profile than a end dump working to unload. You can bet that will be tipped down.
    When under a high wind time do nothing. Wait it out. If you value your equiptment.
  6. snowwy
    snowwy Road Train Member
    20,590
    13,308
    Jul 6, 2009
    Best you can do is get your load off with minimal height needed. Your hauling sand so it's not like you're fighting a sticky load. You shouldn't need to raise to max height.
    Around here. End dumps don't work on high wind days. I've seen one go over.
  7. Agtrucker
    Agtrucker Light Load Member
    156
    45
    Dec 14, 2011
    What direction is the wind suppose to be? What direction/orientation do you have to be to dump off? Do the answers to those questions make a + ? If yes then I'd have cause for concern and be talking to somebody about alternatives. If the wind direction and dumping direction are more parallel then I'd still be aware but be more willing to put it up.
    What are the rest of the drivers doing there?
  8. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Only you the driver can decide if its too windy
    ExOTR Thanks this.
  9. MACK E-6
    49,638
    233,983
    Winter climates can be problematic for dump trailer drivers as well. Freezing can cause the load to stick. I've had that problem with mulch a few times.
    snowwy Thanks this.
  10. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    Not to mention the slight bank that is built into every road by design. We dropped a trailer off Dallas North Tollway this week with 40mph gusts. Rocked the trailer just enough to give it the inertia to start tipping over. I don't lift into the top stage beyond 30mph unless I'm directly facing the wind, your company safety department should be on your side if you don't feel safe in any scenario, drop that trailer on a 300k piece of equipment or a person and you'll get canned in a heartbeat.
    Mudguppy Thanks this.
  11. RET423
    RET423 Medium Load Member
    432
    534
    Apr 6, 2017
    Kalifornia
    If you're on flat ground just throttle it up and eat the seat, that is what I have always done if it's blowing under 35.
    Not very scientific but if had waited for the wind to quit when I hauled hazardous to Kettleman City I would have had to park 11 months per year :)
