Windshield Wiper Problem
Discussion in 'Volvo Forum' started by bossboy2, Feb 20, 2012.
  1. bossboy2
    bossboy2 Light Load Member
    264
    60
    Aug 20, 2011
    Houston, TX
    Truck is an '05 Volvo m670. My w/s wiper system works just fine except when I turn them off. I don't know why but they stop at a 45 degree angle on the windshield, right in front of my line of sight. Like I say, they cycle just fine, no problems there. It's just when they stop, they do so right in front of my eyes. Any help would be appreciated.:biggrin_2556:
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    it is the wiper motor issue. there are parking contacts wheel inside motor and it is worn ore loose.
    KB3MMX Thanks this.
  4. bossboy2
    264
    60
    Aug 20, 2011
    Houston, TX
    Pablo, thanks for you response. Can it be repaired or should I just replace the motor?
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I know guy who fixed it. but I did change
  6. bossboy2
    264
    60
    Aug 20, 2011
    Houston, TX
    Okay. Thanks Pablo.
  7. Mlaz Bogdanci
    Mlaz Bogdanci Light Load Member
    58
    11
    Feb 5, 2012
    Santa Monica , CA
    check with your volvo dealer they had a recall on the '05 670 model regarding this issue
    KB3MMX and bossboy2 Thank this.
  8. bossboy2
    264
    60
    Aug 20, 2011
    Houston, TX
    Thanks, I'll check it out.
    KB3MMX Thanks this.
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    BTW, as I can see 24 V motors are more reliable.... may be it is related with lower currents with the same size. I'd say starter motors of European versions got less problems in 24v system
  10. bossboy2
    264
    60
    Aug 20, 2011
    Houston, TX
    I checked in to the dealership here in Houston and they said my W/W system is not involved in the recall. :biggrin_25510:
    KB3MMX Thanks this.
  11. Mlaz Bogdanci
    58
    11
    Feb 5, 2012
    Santa Monica , CA
    Bunch of BS.It's an easy fix bossboy I had the same problem on my 05 and didn't get a sticker on level one in Joplin because of that even though wipers were working but stoping at 45 deg like you say.99 percent its not the motor but the cycle position.Anyone who knows a little bit can adjust this for you.Just watch out for disshonest shops that will try to push you to change the motor right away.Check at 2-3 different places but its not an expensive fix I'm sure
