Windshield wiper requirements
Discussion in 'Trucking Industry Regulations' started by SHC, May 3, 2011.
  1. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    I had a wiper arm break on me, but luckily it was the passengers side. I called the dealer to get a new one and I was informed that they no longer make it. The new updated replacements require you to change out the entire assembly (pass and dvr) at a cost of roughly $800 for the parts. I have called all the used parts locations and nine have one.
    That being said, are 2 wipers required by DOT? I have to get my annual done next week and not sure if they will pass it.
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Just like a light, if it's there, it has to work or it's considered malfunctioning equipment. Plus there are FMCSA guidelines on windshield visability from the driver side to the passenger side.
    You can find big truck stuff like that on ebay. Give it a try.
  4. Diesel Dave
    8,583
    23,949
    Jan 20, 2010
    Hesperia, Ca.
    YES !!! it has to be there and has to WORK ! I had the passenger side missing as well due to the painter loosing it somewhere. Anyways, I got pulled over a level 1 inspection and got a warning, and my motor carrier(B.I.T.) gave me warning number 2. I finally found one at a wrecking yard next to nothing.
  5. SHC
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    That's what I thought, Thanks.
    I have tried eBay and all the wrecking yards I could locate (online and eBay) Next step is to hit the 4wheeler wrecking yard and see if I can locate it on a car as it is a Bosch arm.
  6. Prairie Boy
    Prairie Boy Road Train Member
    3,258
    1,913
    Nov 18, 2010
    Edmonton, AB
    Why don't you give us the year, make and model of truck you need it for??? Maybe one of us can help.
  7. CondoCruiser
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Yeah we can help. Give us the info. Model before last Camaro/Firebird's had super long wipers. The same with minivans.
  8. gearjammer-2000
    gearjammer-2000 <strong>Clutch User</strong>
    670
    205
    Dec 18, 2007
    columbus Ohio
    take it to a welding shop and get it welded.
    my last truck had the plastic end go bad and no one had it however they did have one that was shorter and so I took the old one cut off the end and welded an end on from the short one, worked fine.
  9. Prairie Boy
    3,258
    1,913
    Nov 18, 2010
    Edmonton, AB
    JB Weld will fix anything.
    panhandlepat Thanks this.
  10. Strider
    Strider The Info Monster
    137
    1,996
    Aug 30, 2010
    Kansas City
  11. SHC
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    Yep, i just got home.
    2004 WS Lowmax 4900EX
    It's the passenger side. It has a small opening for the stud with a bolt thru.
    Welding and JB wont fix it as the all the splines stripped out of the pot-metal end. If all else fails, I will just drill a small hole thru the pot-metal and the stud and pin it in place till i can get around to getting the new arms and the free time to remove the entire dash to replace them LOL
    Thank you for all your help, and I'm heading out to the junk yard tomorrow. Luckily, the arm is short and I might be able to locate it on a mid-90's Buick I have been told?
