Winter clothing
Discussion in 'Experienced Truckers' Advice' started by stacks, Nov 27, 2013.
  1. stacks
    stacks Road Train Member
    1,501
    814
    Oct 27, 2011
    Emerald Isle
    Any drivers have any recomandations where I can purchase good quality clothing and winter boots ' I've checked cabelas seem a little high in price ' branded names there own brand seems reasonable snow boots and hoodies good for cold weather wear .any other outlets what about Walmart do they stock winter wear I've seen a couple of other brands dickies carhart .
  3. Snowshoes
    Snowshoes Heavy Load Member
    878
    664
    Sep 23, 2012
    Pleasant Grove, Utah
    I'm not sure if CAL Ranch is a local Utah chain, or if it is National, but that is where I got all my cold weather gear, gloves, boots, socks, and insulated cuvvies.
  4. Dryver
    Dryver Road Train Member
    2,818
    2,575
    Nov 30, 2008
    Sioux Falls, SD
    I use to buy the well known brands but went to Walmart for a one piece insulated coverall, brand; Wall. Was recommended by a buddy who works construction. Had it 3 years and all zippers are still good and excellent for winter tarping. $65 was all it cost verses a $200 Carhartt or Dickies.
    stacks Thanks this.
  5. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    I'll throw in a good word for the Herman's brand boots sold at Walmart. I have two pair of waterproof Herman's, one pair is steel toe. I've worn the non steel toe pair almost daily for two years and they are still waterproof and very comfortable.
    DoneYourWay Thanks this.
  6. spyder7723
    spyder7723 Road Train Member
    15,471
    25,075
    Mar 31, 2013
    sarasota, fl
    in my opinion it comes down to spend a lot once vs spending a little several times adding up to an even higher price. I've had the same carhart overall and jacket combo for going on 20 years now. And my last pair of redwings lasted over ten years.
    edit to add: I recommend the overall and jacket combo over the one piece coveralls. much better mobility, and can shed the jacket on those cold, but not freezing days
    stacks and MZdanowicz Thank this.
  7. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    on line you can go to sportsmans guide.com, lots of work clothes and footware. there warehouse used to be next to the old truckstop in st. paul minn. have used them quite a bit over the years never any problems. lots of luck
    stacks Thanks this.
  8. Badcable
    Badcable Medium Load Member
    356
    191
    Feb 1, 2008
    Outside Chicago, IL
    There's workngear (.com) that has deals on workwear every now and then.
  9. LoboSolo
    LoboSolo Heavy Load Member
    737
    4,267
    Jun 21, 2013
    Highway 20
    Tractor Supply has a lot of good cold weather stuff, either in their stores or online.
  10. Saddletramp1200
    Saddletramp1200 Road Train Member
    2,111
    2,836
    Sep 4, 2011
    Houston Texas,USA
    Ford. Chevy. I like Carhartt, Red Wing. Last 5-6 years. Cost per unit is good.
  11. Quickfarms
    Quickfarms Heavy Load Member
    898
    236
    May 29, 2012
    Los Angeles, Ca
    Carhartt is what I use
