winter driving...for noobs??help!
Discussion in 'Questions From New Drivers' started by suthernkumfert, Nov 4, 2010.
  1. suthernkumfert
    suthernkumfert Light Load Member
    72
    Jun 18, 2010
    columbus, ga
    the winter is coming up fast and us noobs have never done it...i am from ga so i have never really driven in the snow...so i know once i get behind the wheel of the big truck and find my self in the mountains full of snow i will need some advise...so if yall could help us noobs out with some things to remember and tips to keep in mind i know i would really be thankful for it!
  3. chompi
    chompi Road Train Member
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    If you are ever in doubt pull over. It is better to stop, check the weather and find out what the road conditions are then to just go and get stuck in it. Plus if they shut down the highway you will be much better off in a truck stop then in the middle of the interstate. Make sure your truck is stocked up with emergency supplies. Keep a little extra cash too. Don't ever, ever listen to these other super truckers who tell you it's not that bad and that they aren't pulling over. I cannot tell you how many times I have heard this and the next day when you get back out on the road from shutting down you see those drivers upside down in the ditches. This is no exaggeration whatsoever! Make sure you know how to throw chains. Another good idea is to keep a bag of salt or ice melt with you. This has gotten me out of jams a lot.
  4. walstib
    walstib Darkstar
    Thanks for those links Don, I learned a lot from them and added many items to my list of things I'll need...
  5. Rerun8963
    Rerun8963 Road Train Member
    3,917
    2,012
    Mar 30, 2006
    ova-hereee
    along with this advice, i'd also like to say, try not to get too worked up over weather reports from other drivers on the cb radio. if you listen to enough of them....??? there will be blizzards in your bathroom...>!!!!
    get your self a portable weather radio at radio shack, or wally world.
    as said, stock up on crackers, and fresh water, extra warm clothing, extra pair (or two) of insulated boots. you will do just fine. as far as chaining up tires...?? please believe me, i never had done this myself, as i do not run mountain areas all that much, as i would mostly run a "southern route" when going cross country.
    there will be others coming here soon to help you, but yes, do a search for thread as well.
  6. suthernkumfert
    72
    Jun 18, 2010
    columbus, ga
    thanks..i will have to keep this in mind...
  7. Storm
    Storm Light Load Member
    88
    21
    Dec 2, 2009
    USA
    mostly common sense tho. dont jerk the truck, lock the brakes and soo on
    suthernkumfert Thanks this.
  8. Sara<3sPink
    Sara<3sPink Bobtail Member
    46
    39
    Nov 2, 2010
    Westerville, Ohio
    I know there is other info on the site regarding winter driving, but thank you for posting this thread, I'm new to navigating forums so searching is a concept I'm still trying to grasp....so thanks for the links and possibly for the first time ever, thanks for the repost! Seriously helpful information. I'd always heard that 18 wheelers were champs in the snow, and now I'm learning why....as a new driver who will be starting at the exact same time the snow will (for the Ohio area, anyway) this is all extremely helpful!:msmile:
  9. Racecar17
    Racecar17 Light Load Member
    103
    55
    Oct 5, 2010
    Yucaipa,Ca
    Just slide her up in the big hole and stand on it.....:biggrin_255:
