Winter Driving; lower temperatures are better. Why?
Discussion in 'Questions From New Drivers' started by Ol' Red, Jun 16, 2023.
  1. Ol' Red
    Ol' Red Bobtail Member
    9
    18
    May 22, 2017
    I'm trying to learn as much about winter driving as I can before the season arrives. I'm watching youtube videos of this older truck driver driving the winter mountains, he says that he prefers it when it's way colder.
    Why is colder better in winter driving? What advantage would -20 temperatures have in driving over 10 degree temperatures?
    austinmike Thanks this.
  3. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    The lower temperature the better traction you have. I can't find it now but have seen chart traction vs temperature. With temperature below 0 traction on icy road is same as wet asphalt.
    Concorde, PacoTaco and Cattleman84 Thank this.
  4. Brandt
    Brandt Road Train Member
    4,625
    6,359
    Sep 17, 2012
    When it’s really cold the snow won’t melt on roads making it slippery. It just blows across the roads
  5. Ex-Trucker Alex
    Ex-Trucker Alex Road Train Member
    1,549
    2,703
    Jan 7, 2023
    Well, having driven in Quebec during some of the coldest winters imaginable, I can tell you that at -20° and colder (cold enough that snow 'squeaks' when you walk on it..), traction on snow does improve. Not to the level of bare pavement, and if it gets compacted it will become a rutted, icy mess. But even then, ice isn't really much of a problem until it gets a sheen of melting on the surface. Short of driving into a snowbank, it's actually hard to get stuck when it's -40°; even the mud is frozen solid!
  6. tarmadilo
    tarmadilo Road Train Member
    1,731
    4,771
    Dec 12, 2018
    The thing that makes snow and ice so slippery is the thin layer of water on top that you get as it’s melting because the pavement (or the ground beneath it) isn’t frozen hard, or because the sun is heating it up just enough.
  7. lester
    2,956
    8,085
    Jan 2, 2012
    NW, Iowa
    The colder the snow the dryer it is. Light dry snow presents little problem for traction, it's the blowing that stinks.
    Heavy wet snow is not good for traction. It's like ice.
    D.Tibbitt, Hatt91 and bzinger Thank this.
  8. Antinomian
    Antinomian Road Train Member
    2,175
    3,450
    Feb 17, 2013
    Below around 20 degrees or so the road spray stops sticking to your windshield.
  9. okiedokie
    okiedokie Road Train Member
    13,898
    110,156
    Jun 13, 2011
    PNWET
    Snow in colder temperatures is more abrasive than at warmer temperatures. The ice crystals(snow) form a more ridigid structure. Thus squeaky Snow. Which is great for traction. Point is when you stop on snow roll back & forth and cool your tires down before parking. Otherwise you'll melt the snow under the tires. Then you're stuck. Follow me for more Winter driving tips. :biggrin_25518:
    Opus, austinmike, Concorde and 5 others Thank this.
  10. Cattleman84
    Cattleman84 Road Train Member
    10,019
    71,546
    Nov 1, 2017
    The Sticks, Idaho
    When I was OTR I prefered to drive at night... Especially during the winter. Being much colder at nightbwas one of the reasons, as you get better traction when everything is frozen solid with no thin film of melted water on top of the ice.
    austinmike, Concorde, lester and 4 others Thank this.
  11. supergreatguy
    supergreatguy Road Train Member
    1,030
    2,896
    Nov 26, 2020
    Driving in the winter is most cherished because when the hot coffee becomes too much for your heart, you can switch to hot coco to soften your heart.
