winter-fronts, why are they no longer needed or used?
Discussion in 'Questions From New Drivers' started by ad356, Dec 24, 2018.
  1. ad356
    ad356 Road Train Member
    2,138
    3,179
    Mar 13, 2017
    long before i had my CDL i worked for a trucking company in the wash bay. my responsibilities included washing food grade tankers. i would get inside the tankers and hose them out, drop the CIP spray ball and sanitize with 190 degree water. i would also wash the outside of the tankers and the tractors, this was 2001-2003 or so. at the time the company's fleet comprised of T800 with CAT engines. i remember every winter they would install winter fronts, that was a cover that went over the grill. trucks no longer require those. i was wondering what changed that they are no longer used.
    i had an interest in driving back then but i was too young at the time. i didnt just wake up one day and say i wanted to drive truck, i was around allot of trucks prior to getting a CDL-A
  3. Omega1
    Omega1 Heavy Load Member
    721
    1,598
    Nov 18, 2017
    Oregon
    Modernized equipment has made them virtually unnecessary unless you are running one of the older trucks.
    Studebaker Hawk Thanks this.
  4. SteerTire
    SteerTire Road Train Member
    1,414
    2,346
    Nov 5, 2018
    Behind the wheel
    I can’t give you an answer to that. But can tell you that Freightliner was tagged by the EPA a few years ago. For too high of heat reading in the engine compartment. They were forced to make some adjustments
  5. Chinatown
    Chinatown Road Train Member
    76,753
    178,717
    Aug 28, 2011
    Henderson, NV & Orient
    Global warming makes winter fronts obsolete.
  6. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    At normal running operation, the new engines run plenty warm enough outside of extreme cold temps. Since idling is discouraged, and most have APU's, they're just not really needed or desired unless the temps are regularly down below +10f, and even then they're not really needed unless you idle for cab heat.
    Jazz1 Thanks this.
  7. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    Mine goes on at -25 to make my beauty sleep cozy. Otherwise no need if you going to keep moving
    truckdriver31 Thanks this.
  8. dclerici1
    dclerici1 Medium Load Member
    525
    1,583
    Aug 1, 2012
    Shell Knob, Missouri
    One item that made the winter front obsolete is the fan clutch. Also advancements in thermostat and water pump designs, the installation of the charge air cooler in front of the radiator contributed.
  9. Allow Me.
    10,724
    12,418
    May 28, 2009
    Rancho Mirage, Ca.
    my winter front was a piece of cardboard ! (redneck style):hello2:
    OLDSKOOLERnWV, Lepton1 and 91B20H8 Thank this.
  10. 25(2)+2
    18,756
    45,800
    Sep 18, 2006
    the road less travelled
    We have them, but I don't put it on until I expect the temp to stay below 10 degrees F. It comes off when it gets warmer than low 20s.
    Snaps were lost on the last truck when the grill had to be replaced, so I never used one last winter after getting it back.
  11. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    I think the biggest reason you don't see them on any company trucks is because it'd still be there in June, maybe I'm wrong about that. Newer motors are getting enough fuel they stay warm on their own.
    snowlauncher Thanks this.
