Winterfront and Volvo's
Discussion in 'Volvo Forum' started by Socal Xpress, Dec 19, 2015.
  1. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    So why are other brands sporting the winterfromts and I have yet to see any Volvo's?
    I have run some miles with sub zero temps and my truck holds steady at 180ish. Weight and grade make a difference of course.
    So whats the consensus on when Volvo's use the winterfront? Or do we just not need it?
    Thanks
    Ivan
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    If your temp stays good no need for it.
    Bob Dobalina Thanks this.
  4. Bob Dobalina
    Bob Dobalina Road Train Member
    2,578
    4,456
    Sep 20, 2015
    The "Buckeye"
    I had a Volvo overheat in very cold temps while climbing a hill because of ice on the grill, which created its own winterfront-like situation. I'm sure they're probably necessary on some trucks in very extreme cold, but the thermostat should take care of it in most cases. Last winter I used a winterfront on a new Freightliner and the fan kept kicking on. So I took it off.
  5. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    Volvo cooling system is better designed to maintain temps in cold climates.. Engine "warm hold" feature is one example.
    IMO their biggest problem in the winter is plugging of the grill with snow/ice.
  6. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    I've had 2 780's, never put a winter front on either of them.
  7. v6killer
    v6killer Medium Load Member
    446
    122
    Dec 6, 2010
    ChicagoLand
    Winter fronts will kill the intercooler on a Volvo.
    KB3MMX Thanks this.
  8. Newto Trucking
    Newto Trucking Medium Load Member
    359
    225
    Dec 26, 2013
    NE Illinois
    Can you explain why?
  9. sirjeff
    sirjeff Medium Load Member
    437
    1,259
    Dec 1, 2013
    Kootenays, British Columbia
    I found the need for a winter front when I ran a 2 speed fan hub. The low speed is magnet driven and constantly on, it overcooled in the winter. Since putting in a regular ol on/off hub, haven't needed a winter front
    Newto Trucking Thanks this.
  10. Amram
    Amram Medium Load Member
    448
    234
    Feb 4, 2017
    I put mine on below 20 degrees to help me stay warm. Cuz when that cold I gotta crank my heat all the way over. Mine came with the truck.
  11. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    I have a Detroit DD16, I don't put on the winter front until it gets under -25.
