Winter's comin', what's the best area if I want to stay busy?
Discussion in 'Questions From New Drivers' started by JustSonny, Oct 10, 2010.
  1. JustSonny
    JustSonny Big Dummy
    6,038
    5,785
    Oct 22, 2009
    Troutman NC
    I'll be off the Swift Developmental Team in a few weeks. Winter will be here not long after that. I'm not bound to any part of the country with respect to hometime. Where should I go, winter freight wise, to keep moving?
  3. RenegadeTrucker
    RenegadeTrucker Road Train Member
    2,754
    2,383
    Dec 25, 2009
    Montana
    If you are willing to go north and play in the snow, you will be able to run.
    There are lots of truckers that once the snow starts flyin, they get cold feet and want to run south. Being willing to run in the snowy white north will keep you loaded and moving. Just dont take loads that final in the Dakotas, western nebraska or eastern montana. Trying to get out of there in the winter can be really #### hard.
    Allthough I know swift does have several hauls out of the area.
    JustSonny Thanks this.
  4. pcozzy
    pcozzy Bobtail Member
    29
    Sep 25, 2010
    thanks, i had this concern, not that i dont want to drive in snow, but it becomes stressful and fatiguing.
  5. RenegadeTrucker
    2,754
    2,383
    Dec 25, 2009
    Montana
    Snow aint nothing to be scared of, it is something to be respected.
    Winter driving is a skill just like backing up your trailer, learn it right and you will be able to truck all winter long with out issue. Think it is time for a winter driving tips thread.
  6. wildbill123
    wildbill123 Heavy Load Member
    713
    322
    Jan 31, 2009
    SE,MI
    You can stay reasonably busy running the east coast any time of year. My brother in law has been an OTR owner op for 36 yrs. he runs mid west all year long. He does kind of a triangle, South Dakota to Pa. down to St. Louis area then back up to South Dakota. He lives in Michigan. Although he says Dakota winters can be a real pain at times.
    Just a note on winter driving. Don't run up against the governor on slick roads. Run just above a lug, that way if your drives let loose you will be able to hear it through the exhaust and it will give you time to get off the throttle. You may have been taught that already, but I just thought I would throw it out there.
  7. JustSonny
    JustSonny Big Dummy
    6,038
    5,785
    Oct 22, 2009
    Troutman NC
    That's good info! I was not taught that and I'm sure glad you mentioned it. Thinking about it now, I can understand the reasoning. Thanks!:biggrin_25514:
  8. thelastamericanhippy
    thelastamericanhippy Road Train Member
    1,038
    311
    Jul 10, 2010
    jacksonville, fl
    keeping your RPM ---UP-- prevents torque from breaking tires loose......
    hunts2much and JustSonny Thank this.
  9. Larryparker
    Larryparker Medium Load Member
    334
    215
    Jan 23, 2010
    Boynton beach, FL
    Something else you might want to try before the winter is Chaining up. Alot of guys will say that if you have to chain, its time to pullover, and for the most part I agree. But there will be times when your half way up the hill and loose traction, you have to throw iron. Doing it now, on the next month will treach you how to do it with out being cold and wet, and will also show you what conditions your chains are in. I hope you realizde that in many parts of the country you already need to be carring chains already, and almost every state has a diffrent requirement. Will you use bungee cords on your chains, I do. 2 to a wheel, do you have them on your truck, are your chains serviceable? Just a few thoughts that I hope will help someone this winter.
    Safe miles, Good health.......
    Larry
    wulfman75 and JustSonny Thank this.
  10. AZS
    AZS Honk if anything falls off
    2,912
    1,303
    Sep 30, 2010
    PHX, AZ
    What is the swift developmental team by the way? Is that like another probation phase after the mentor phase? They keep you closer to home I'm guessing. How long does that last?
  11. RenegadeTrucker
    2,754
    2,383
    Dec 25, 2009
    Montana
