Wiring a mini split
Discussion in 'Ask An Owner Operator' started by TruckerPete1990, Jun 29, 2022.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,377
    Jul 16, 2012
    Bentonville Arkansas
    I have a carrier apu and let me say this. The cooling sucks even on a 90 degree day I find myself idling every now and then as the cab is still hitting 75...
    Was thinking my apu comes with an extension cord would it be safe to wire up a mini split to that cord and run the mini split that way?
  3. race27
    race27 Bobtail Member
    40
    31
    Jun 8, 2019
    it will be fine as the mini split pulls little power being inverter technology. i run a 12000 btu mitsubishi and it will even run off a 2500 inverter if needed but the best way is with a generator as the generator used way less gas. a predator 3500 will run 10 hours with the mini split blowing 62 and only use a little over a gallon of gas. thats a lot less than running an apu for power source. 12000 btu is a 1 ton unit and in the middle of the day u can hang meat it gets so cold. mini splits are very efficent
