Wobbly side box
Discussion in 'Ask An Owner Operator' started by God prefers Diesels, Nov 1, 2020.
  1. God prefers Diesels
    4,198
    22,261
    Jun 26, 2020
    South Texas
    I bought a 24x24x60 toolbox for between my spread axles. I fabbed brackets out of angle iron, and used a piece of flat strap to make them a "triangle". Just regular brackets. Anyways, now I've got everything loaded in there (probably 200 lbs), I can shake the box up and down. If I keep at it, I can really get it moving. Maybe 3/4" of movement at the farthest edge. I'm worried about metal fatigue as I'm driving down the road.
    Are your boxes solid, or do they wobble too?
    D.Tibbitt Thanks this.
  3. JonJon78
    JonJon78 Road Train Member
    7,171
    40,300
    Jul 1, 2018
    Mine are solid...
    My guess would be yours aren't completely level which is causing the wobble?
  4. God prefers Diesels
    4,198
    22,261
    Jun 26, 2020
    South Texas
    No, they're dead level, square, and secured. I've got the bottom of the box bolted down with four 3/8 bolts. The back of the box bolted with four more 3/8 bolts. The brackets are bolted to the trailer frame with four 1/2 bolts.
    The toolbox and brackets aren't moving independent of each other. They're all wobbling together. Now they don't just wobble "easy". I have to push them up and down, and keep at it for a few seconds before I really get it moving good.
    D.Tibbitt and JonJon78 Thank this.
  5. God prefers Diesels
    4,198
    22,261
    Jun 26, 2020
    South Texas
    I guess a better way to explain it is all the mounting points are solid, but the whole apparatus is kind of flexible. Springy.
    JonJon78 and D.Tibbitt Thank this.
  6. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Quit doing that problem solved!
    D.Tibbitt and God prefers Diesels Thank this.
  7. God prefers Diesels
    4,198
    22,261
    Jun 26, 2020
    South Texas
    LOL, I'm just worried what's going to happen when I start going down the road.
  8. Ridgeline
    22,469
    117,832
    You using three inch angle iron, that’s three inch per side?
  9. God prefers Diesels
    4,198
    22,261
    Jun 26, 2020
    South Texas
    No, two inch. 1/4" thick. And the 1/2" bolts holding it to the frame are 6" apart. (that's about the best I could do)
  10. Spyro2112
    Spyro2112 Medium Load Member
    604
    416
    Mar 17, 2018
    Put a piece of metal between your bolts, more leverage, it just the floor of the box moving
    God prefers Diesels and D.Tibbitt Thank this.
  11. D.Tibbitt
    151,387
    Once u put a couple hundred pound of equipment in it . It wont move. Mine was the same way until i loaded it up with equipment... and i beat down some bumpy dirt roads too. Dont have any problem
    JonJon78 and God prefers Diesels Thank this.
