Won't start - 06 Pete 387
Discussion in 'Peterbilt Forum' started by Stormbk, Mar 25, 2015.
  1. Stormbk
    Stormbk Bobtail Member
    17
    Nov 5, 2014
    I will try to be brief, but I'm stumped. 06 Pete 387 915k mi went to start and turned over slow typical of low batt voltage so I fired up the apu and it wouldn't even start got it jumped turned the key - and
    nothing like power was completely dead. So I tried my signals
    and my dash lites came on but no blinkers no hazards. Parking lites on the roof were lit up but
    not on the headlights or tail lights on tractor And Trailer. Then my gauges started going wild from right to left and both abs lights stayed lot but cycle through all other indicators. Was able to remote start it but only cranked good-DIDNT Fire up.
    performed the usual checked all grounds cleaned all battery posts tightend All. Cleaned around starter alternator tightened check all voltages found one
    battery won't hold a load. Replaced. Checked wired for rubbing corrosion or weAr. Negative checked all fuses not one bad.
    Totally stumped as elog not showing any codes and several good mechanics and calls to Peterbilt everyone still scratching their heads. Spent 12 hours troubleshooting and all the symptons are the same. Domes, apu, pw, cb, stereo all work please please give me your thoughts. I towed the rig to my mechanics and need to get this figured out
    thank you
  3. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    Got the same truck, 475 cat. Slow start was a bad connection to starter, turned the nut a quarter of a turn and it was fixed. Also replaced the starter.
  4. xsetra
    xsetra Road Train Member
    5,119
    6,995
    Aug 21, 2011
    Yes the post on your starter could be loose. My old starter also did that. Where the nut tightens on to hold the positive cables. The exterior nut was tight, that stud was loose in the starter.
  5. RSQ20
    RSQ20 Medium Load Member
    Tell the tech to get his meter out...
    ... Philip
  6. Stormbk
    17
    Nov 5, 2014
    Lol his meter needed a battery. Got a different Meter. Turned out it was a bad battery, broken wire and a mega fuse
  7. RSQ20
    Amazing what can be accomplished with the correct tools...
    ... Philip
  8. Stormbk
    17
    Nov 5, 2014
