Wood Floor Dump Truck
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by kev2809, Sep 4, 2016.
  1. kev2809
    kev2809 Light Load Member
    211
    56
    Jul 2, 2015
    ive had my dump truck for a yr now..with the same old ugly bed. its 17ft, and would lean like crazy when i first got it. i stiffened up the under frame on it by welding box tubing a few feet apart throught the frame and it helped tremendously.
    the floor on the other hand is just hideous. floor is real dented up and i get dirt stuck daily...real annoying. was wondering if people really lay down wood to help out. i was thinking of putting small 1 inch thick wood in the dips, and laying down 2x10s longways throught the entire floor. anyone try this? cost of replacing my floor was about 2800..which is not worth it for this box. just want keep cost down. my truck empty weighs about 25k pounds, which is also a concern.
  3. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    If you think it sticks now, get some wet dirt on the wood and see how fast it builds up.
    gwilli89 Thanks this.
  4. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Or wait till winter when it starts freezing.:oops::dmage:
  5. kev2809
    211
    56
    Jul 2, 2015
    well i also have a plastic liner from an end dump i was given..if i need to use it. was maybe trying to avoid using because of the added weight
  6. SL3406
    SL3406 Medium Load Member
    550
    1,482
    Jan 10, 2011
    Oklahoma
    The wood by itself won't work. Like others have said the dirt won't slide out over it when it has moisture in it. Maybe the liner over the wood would work. You're in uncharted half assery with that so I couldn't say how well it would work.
    Ruthless Thanks this.
  7. kev2809
    211
    56
    Jul 2, 2015
    can u explain the half assery?
