Working load limit confused me?
Discussion in 'Questions From New Drivers' started by Nuge31, Nov 3, 2017.
  1. Nuge31
    Nuge31 Light Load Member
    80
    54
    Sep 7, 2017
    When direct hooking, which to my understanding is you hook both ends of your securement device to the same side of the trailer, you cut the weight in half of whatever you are carrying. Nowi also hear people say when you go across load to other side of trailer, you divide load in half.. to be on the safe side I am securing everything to the weight of the load.. but I am spending allot of time messing around.. can I get some clarification on that explained in a way that my simple self can understand.... Thanks brother
  3. zinita17601
    zinita17601 Road Train Member
    1,317
    1,603
    Aug 19, 2010
    lancaster pa
    From one side of the load to the trailer thats indirect 1/2 wll.securement over the load to both sides thats direct WLL.
    The way i've being doing it 80%weight to keep the load from going forward 50% backward 20% upward.
    U gotta have a strap every 10 linear feet regardless of the weight.
    Also the WLL to consider is the weakest one on your securement
  4. Nuge31
    80
    54
    Sep 7, 2017
    Ok, let me try a story problem.. if I have a 30k plate of steel, I will be strapping with a strap from the driver's side and connecting it to the passenger side. I need to provide 15000 lbs of securement as long as I am good with the every ten feet rule 2 to be legal. That would be 3 5400lb straps.. but 80% is 24k lbs, so I would throw 2 more just to be safe.. does that sound right?
  5. zinita17601
    1,317
    1,603
    Aug 19, 2010
    lancaster pa
    Thats what i would do but instead of two extra straps i will put two chains,starps Wont keep the load from sliding but chain will bite into the metal and stops ur load from moving.u have to verify with the shipper if u can use chains
  6. Rooster1291979
    Rooster1291979 Road Train Member
    1,308
    1,751
    Sep 4, 2012
    NOLA
    Load to trailer is direct. Trailer to load to trailer is indirect.
    You need a strap for every 10' of length but, the strap doesn't have to be every 10', except for the first and the penalty. If you have no bulkhead you need a penalty strap. That must be within the first 10' of the load.
  7. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    The penalty strap is no matter what.
    Anything exceeding 5' or 1100lb's requires a min of 2 straps, from there the written rule is,
    2 straps for the first 10' and 1 for every subsequent 10' or portion there of.
    10'=2 straps
    11-20=3
    21-30=4
    Ect... and wll may increase your required securement
    Rooster1291979 Thanks this.
  8. Rooster1291979
    1,308
    1,751
    Sep 4, 2012
    NOLA
    You sure on the penalty? The way I understand it a qualifying bulkhead removes the penalty strap requirement.
  9. street beater
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Nope. After 5' its 2 no matter what, (barring stuff like beams lumber ect...
  10. street beater
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Trust me! I lost a weeks pay over this exact thing!
