working with Con Way LTL, Can i Tranfer from OTR to linehaul..
Discussion in 'Con-Way' started by Roadwarriorking, Apr 1, 2012.
  1. Roadwarriorking
    Roadwarriorking Light Load Member
    106
    7
    Mar 24, 2012
    Miami, Fl
    i live in Miami Fl.. getting out from CDL school...i got a friend that he's pushing me to go to USX as a team said make good money .. but i see alot of Good reviews about Con Way ...i know there is 3 diferent branch.. Con way truckload, Con way LtL and Con way freigh....
    my plan is to stay with one company i dont want to be jumping around from company to company and the same time make good or decent money..
    i am planing to go as a team with my cousin with Con way LTL....but my question is, can i tranfer from LTL OTR to linehaul after one year or two..i been reading make more money and ur home every day...
    can we do linehaul as a team or is only for solo driver?.
    thank you ..
  3. CenutryClass
    CenutryClass Road Train Member
    1,539
    859
    Feb 15, 2006
    You've your info a little jumbled.
    There is conway truckload and conway freight(the LTL side). And also the LTL side is where linehaul comes into play
    Conway truckload has teams which they seem to keep moving. LTL side is home daily unless they run an extended lane and run teams..Wont see that anytime soon.
    So if you're looking to run teams, conway truckload is the way to go. But if you eventually want to get into LTL. I would start right away as that would be one year of seniority that you'd have as opposed to going with truckload first.
    All depends on what you want to do
  4. Roadwarriorking
    106
    7
    Mar 24, 2012
    Miami, Fl
    thanks for ur reply...yea i like to do team first with my cousin to get some experience, But if i do OTR as a team with Con way truckload....so i can't get a transfer to do linehaul after a year or two .?....
    if i start as LTL, i will be driving solo only or working at the dock too..?
    thanks for help..appriciated
  5. Roadwarriorking
    106
    7
    Mar 24, 2012
    Miami, Fl
  6. CenutryClass
    1,539
    859
    Feb 15, 2006
    LTL is working the dock and a little driving, depending on how far the closest FAC you run to is..Being in Miami i cant see it being too far from the terminal. And yes its usually solo and most of freight runs are made to be done in the 11/14 window. Some other LTL companies have layover runs.
    If you want to do LTL ultimately, id say forget the OTR teaming with your cousin. LTL is seniority based, and if you wait a yr, youll be a year behind. So if thats what you want to do, then just apply for freight f.rom the get go
    But yes you can transfer from conway truckload to conway freight in a year. But you will go to the bottom, as your OTR experience is just that, experience. You keep vacation time and stuff, but thats it.
    Roadwarriorking Thanks this.
  7. lonewolf4ad
    lonewolf4ad Road Train Member
    7,743
    7,773
    Nov 4, 2008
    Displaced to Colorado
    Century, I am going to argue with you (but only a little) I think his driving OTR would be better for him in the longrun, even if he does lose a year of seniority. The reason I suggest this is due to the nature of the docks you LTL boys hit sometimes, the driving he will experience as an OTR driver will do him quite a bit of good as it will prepare him for more than dock work (I really mean no offense). Right now with CSA cracking down so hard if he can learn OTR it gives him a better experience level to draw on when/if he switches to freight.
  8. jakebrake12
    jakebrake12 Road Train Member
    1,576
    1,047
    Feb 15, 2008
    I95
    That's a tough call. I have a little over 10 years total driving now and a little less than 9 years at Freight. That year and a half would have me up about 15 seniority slots at a big terminal. Had I started later, I'd be down the board further and there's no way I'd have the slot on the run I currently do.. It's a roll of the dice..
  9. mickeyrat
    mickeyrat Road Train Member
    7,859
    7,542
    Nov 24, 2011
    on my 30 min break
    I know it varies by terminal, but what are you seeing for new guys in general? is there work/runs available? have just submitted my app for freight.
  10. CenutryClass
    1,539
    859
    Feb 15, 2006
    more than likely you'll go to the flex board. Unless luck is on your side and you slide into a line/p&d slot.
    Youll get the shortest run, but hey as long as there is consistent work and you ca pay your bills, just do what you gotta
    ACH1130 Thanks this.
  11. ACH1130
    ACH1130 Road Train Member
    2,695
    825
    Jan 23, 2011
    Land of far far away,
    I never drove OTR, I had no desire since I got too much going on and didnt want to be away all the time. I knew some LTL companies would keep you out one night which wouldnt of bothered me. When I worked at CWF i started as an apprentice without any experience. If you want to do OTR, then its up to you, but if you dont you do not have too. This is a thread on here that someone made that tells you how to get into a local gig right away. Its best to get in with an LTL company sooner the better due to its all based on senority like century described.
    CenutryClass Thanks this.
