Worst bridge you’ve crossed?
Discussion in 'Questions From New Drivers' started by Mototom, Jul 27, 2019.
  1. Mototom
    Mototom Road Train Member
    1,388
    2,703
    May 7, 2019
    yesterday I almost met my end coming across MO/IL 60/51 the narrow 2 lane bridge that crosses the Mississippi.
    It’s hardly wide enough for 2 trucks to pass side by side and has a 25mph posted speed limit. I was almost to the end and I had a flatbed drive cross head on into my lane doing atleast 50. I was forced up onto the wall to avoid having his trailer crush the front of my truck. My company is sending the footage to his because of the way he was driving. No damage to my truck thankfully.
    Are there any bridges trucks should try to avoid or that you personally try to avoid (that are not obviously restricted)
    I’ll be using a red marker on 60 and 51 in my atlas’s. Don’t think I’ll come back that way again.
    blairandgretchen Thanks this.
  3. Puppage
    Puppage Road Train Member
    4,266
    7,381
    Aug 2, 2012
    Connecticut
    Wow. I am glad you’re ok.
  4. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    as far as I know that bridge is not for truck. another bad place is double bridges near Cairo, IL US 60. Before getting to bridges there are two sharp turns and road is not wide enough . the bridges are old and not wide, you need to be very careful there.
    91B20H8 and shogun Thank this.
  5. ZVar
    ZVar Road Train Member
    10,911
    23,830
    Sep 10, 2010
    Flint, MI
    No "No Truck" or even weight limit signs looking at Google maps. And while a bit narrow it's far from as narrow as the op implied. Also I didn't see any speed limit signs, although there was construction so it might now have some.
    Plenty of room for two trucks to pass. To me it looks like the op simply panicked.
  6. DougA
    DougA Road Train Member
    1,429
    8,892
    Dec 16, 2013
    Retired,In my shop in Md.
    Back in the 70's we used to sneak across the old Cheat Lake Bridge,by Morgantown,W.Va. Bridge which was weight restricted, but if you were trucking from Baltimore to Charlestown,W.Va. area,you either sneaked across the bridge,or else you had to drive up US 40 to Uniontown,Pa. to cross the river. Lots more serious mountains and miles,I-68 wasn't built then. When you got off the bridge on the west side there was an immediate hard left switchback,and if you were driving anything longer than a 40' trailer,and a CO,you couldn't make the turn. That's the road you see in the foreground. Wonder that old bridge was still standing after all the heavy mine jacks we hauled across it back then. Heres a Utube of them finally blowing it up. The bridge in the background is I-68.
    Farmerbob1, JadeLove and x1Heavy Thank this.
  7. WesternPlains
    6,333
    56,224
    Sep 1, 2017
    Rapid City, SD
    Looks like Hwy 60 is just plain bad. Don't try it over the Ohio river. Going from Kentucky to Tennessee. Two bridges. One bad enough. Second is ludicrous. Must have been less than an inch of clearance between mirrors. Only one truck came the other way on me.
    TravR1 and mhyn Thank this.
  8. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    once I needed to cross Mississippi from MO to IL. This Chester bridge was the short cut. I checked on Truckers Atlas and I saw there is no truck designed route to this bridge in MO. My common sense did not let me use this bridge. If no truck designed route to the bridge that crosses Mississippi then the bridge is narrow/bad one.
  9. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    I know one more narrow bridge. it's near Brownville, NE on us 136.
    bzinger Thanks this.
  10. FlaSwampRat
    FlaSwampRat Road Train Member
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    Oxford PA. It used to say 9.5' and I had to deliver to the water treatment plant you can see in the background. I was in a 10' 8" UPS truck when I first came up to it so I called the police station to ask a way around because the other bridge I came up to was weight restricted to like 5 tons or something (this was flip phone days with no GPS). They told me to go ahead across and it's actually 12' if I remember correctly, they put the low height to scare trucks away from it. I guess they have upped it since then so smaller delivery trucks would go across. Screenshot_20190727-103624.png
  11. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    I don't like that sharp turn just before going onto Ohio river bridge in KY. if I see truck is coming from bridge I wait until it will pass that turn and then I go to bridge.
    WesternPlains Thanks this.
