Would y'all drive with this steer tire?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Milkyway2025, Aug 5, 2025.
  1. Milkyway2025
    Milkyway2025 Bobtail Member
    Oct 20, 2024
    Outside shoulder of Passenger side steer tire is wearing out a lot faster than the driver side tire. You can see rolls of rubber on the tire in the photo attached ( not normal, right?) also looks like there is cupping/waviness on the shoulder. And the wear is only on the outside shoulder.
    Shocks and other components look ok. Any idea what could be the cause?
  3. Big Road Skateboard
    6,264
    34,539
    May 2, 2021
    Looks like an alignment issue. I'd run it out myself, but keep a close eye on it
  4. wore out
    wore out Numbered Classic
    16,077
    194,709
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Damage is done run it. Its not a bad tire rather a mechanical issue causing the wear
  5. Powder Joints
    7,702
    7,822
    Sep 25, 2007
    Rosamond, SoCal
    run it, just check it . This is summer out here in the west you can get close to 200 degree highway temps in some area.
    Milkyway2025 Thanks this.
  6. Arctic_fox
    4,122
    21,392
    Sep 16, 2016
    Its fine. Keep an eye on it, and run it.
    hope not dumb twucker Thanks this.
  7. 201
    201 Road Train Member
    12,403
    25,357
    Apr 16, 2014
    high plains colorado
    There's still a lot of rubber there, I'd regroove it and run it on the trailer. An inspection however would probably put you out of service for that.
  8. Goodysnap
    Goodysnap Road Train Member
    3,724
    9,049
    Jul 12, 2017
    Michelins always look like this on the edges when they get wore down. They have a little life left but will need replaced soon.
    Min tread depth is measured at the first major tread groove not at the outer edge rib and cannot be below 4/32 on steers.
  9. Deezl Smoke
    Deezl Smoke Medium Load Member
    504
    329
    Feb 12, 2011
    Hillsboro Oregon
    Luwi67 and Milkyway2025 Thank this.
  10. Milkyway2025
    Oct 20, 2024
    Deezl Smoke Thanks this.
  11. Luwi67
    Luwi67 Heavy Load Member
    747
    484
    Oct 24, 2012
    Long island
