Would you plug am 800 watt cobra inverter into your cigarette lighter?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by A Bug, Jul 27, 2018.
  1. A Bug
    A Bug Heavy Load Member
    918
    1,864
    Mar 15, 2014
    Sevierville TN
    I am wanting to get a 700 watt microwave for the road. Would an 800 watt inverter burn out the cigarette lighter?
    Should I instead get one wired up to a battery instead?
  3. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
  4. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    Shouldn't be a problem...
    lagbrosdetmi Thanks this.
  5. A Bug
    918
    1,864
    Mar 15, 2014
    Sevierville TN
    I believe you. Got to wonder why they make these things to plug them into that socket though.
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,296
    Apr 9, 2009
    Humboldt, Sk
    150 watt max from a standard lighter outlet, 240 Watts for heavy duty ones.
    Otherwise must be direct wired to battery with heavy enough gauge wire.
    25(2)+2 Thanks this.
  7. ZVar
    ZVar Road Train Member
    10,911
    23,830
    Sep 10, 2010
    Flint, MI
    Just in case you did not know, you multiply amp x volt = watt.
    So cig lighters are what, 15-20 amp fuses (and by extension, wire) So taking the 20 amp x 12v = max wattage of 240 watt. Of course that is absolute max and likely will not be able to sustain the current before a fuse blows.
    So I guess it's a long winded way of saying no, it will not work.
