here's some food for thought.. I've been reading on here more and more often cases where a person goes to XYZ truck driving school and learns how to drive an autoshift and not a manual. I may be off my rocker here, but when I learned to drive, I was made to learn on a manual. So, my question is this- would it not be better to require newbies to learn in manual transmissions, so if and when they do switch jobs, they aren't confined to autoshift-only companies? And for the experienced driver who likes the auto better, let them have it. I realize a newbie is more prone to tearing up a tranny, and I dont have a clue how one would address that, but in the end, would it not be safer? If I posted this in the wrong place, please move to the proper place. thanks
wouldn't it be smarter?
Discussion in 'Experienced Truckers' Advice' started by rbrtwbstr, Dec 21, 2012.
Page 1 of 3
yes, that is part of the problem in trucking now. the trucks are so easy to drive just about anyone can drive one. in these so called schools soon as you can fill out a log books you are good to go. b careful out there
I think this is one of those nuance discussions which will never go away. Yes, it certainly would be smarter to learn on a manual, and to get some experience driving them before driving an autoshift truck. The manual transmissions are still predominant.
But let's say someone comes out of school and gets on with a carrier that works out good for them, and they happen to use the autoshifts. I couldn't really sit there and tell someone to pass up a good job on account of an automatic transmission. -
Growing up in Germany and geting my first of many licenses over there you would have a restriction on your license. If you went through a driving school on an automatic they would note that on your license and you could not drive a manual. Not sure if they still do that, but it made sense at the time.
I do drive a 12 speed I-shift Volvo and would not go back to a manual if given the choice. I run California a lot with downtown L.A, San Francisco , Oakland and several other cities for stops and it makes it so nice not have to use the clutch and shift. -
http://www.thetruckersreport.com/truckingindustryforum/ask-an-owner-operator/18260-advantages-and-disadvantages-automatic-transmission-gear.html
http://www.thetruckersreport.com/tr...rom-new-drivers/191802-why-not-automatic.html
http://www.thetruckersreport.com/truckingindustryforum/trucking-jobs/34947-automatic-trucks.html
Just a few off the list. -
Every single "new" driver should have to be taught on a standard trans. You should have to have that capability and knowledge before you are allowed to possess a CDL.........Never know even if you get a restricted license (auto only) and your truck has a breakdown...the rental place has only standard trans. well you are stuck, and more importantly your employer is.... his customer's load don't move cause "his" professional driver can't drive a standard trans.......
rbrtwbstr Thanks this. -
No you said it just fine..your point was clear and spot on. I just had another example of how the problem could be if a newbie was put into that spot.
all the threads on autos none mention learning on autos
I know of no school teaching on autos
In NJ you get a restricted license for testing on an auto
and yes I drive an auto but can drive a quad box can you? -
yeah as a matter of fact, I can drive a quadbox, although I'm not very good at it. If anyone drives an autoshift and likes it, thats great. I drove one for two years, and kinda liked it. My point was simply that every driver should be trained/tested in a manual so in the event of a breakdown, emergency or whatever, the driver isnt limited to searching for an auto
Logan76 and Tonythetruckerdude Thank this.
Page 1 of 3
