Written up for safety
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by moptop, Sep 10, 2017.
  1. moptop
    moptop Bobtail Member
    6
    10
    Oct 24, 2011
    I refused a route that would have put me in Tallahassee, FL around 2-6am Monday. Something about delivering food in a strong hurricane sounds unsafe.
    Given the way my 'leadership' has been acting, I'm sure they have a write or even a termination waiting on me.
    If I can't get help from human resources, which is in Temple, Tx, what is the best course of action?
  3. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,755
    Sep 20, 2014
    The hurricane will be gone by then I would think.
    Isn't it a bit early to worry about what to do if you haven't faced disciplinary action yet?
    CrappieJunkie Thanks this.
  4. driverdriver
    driverdriver Road Train Member
    4,254
    5,282
    May 30, 2011
    Call your safety department.
    Lonesome Thanks this.
  5. DTP
    DTP Road Train Member
    1,281
    2,708
    Dec 9, 2014
    You should never do anything you don't feel safe doing, within reason of course. I wouldn't be taking a load into an area under an active hurricane warning either. You get blown over or flooded out, it'll go on you and your record.
    Find it very hard to believe any shipper/receiver would be open Monday there anyway...
  6. metallifreak10
    metallifreak10 Light Load Member
    215
    174
    Aug 20, 2010
    Wishing I was in Alaska
    Actually no. Hurricanes are pretty slow moving.. the storm is expected to still be category 3, and over Tallahassee on Monday Morning.
    uncleal13 and Hulld Thank this.
  7. scythe08
    scythe08 Road Train Member
    2,821
    3,598
    Mar 19, 2007
    Portland, Or
    I wouldn't have done it. Even if it had passed, those areas may have alot of residual damage left, plus people coming back into
  8. MACK E-6
    48,145
    219,822
    I wouldn't do it either, but I'm sure the mega carrier pointy heads with all of 2 brain cells to rub together and the common sense God gave a rock would compare wanting to stay away from Hurricane Alley with simply not wanting to deliver anywhere with snow on the ground. :rolleyes:
    bzinger Thanks this.
  9. Wicked Wizard
    Wicked Wizard Heavy Load Member
    985
    857
    Jul 15, 2008
    Northeast PA
    Dispatch always tells drivers to do stuff that they have no idea on. It is your life/license, be safe as possible. Tomorrow is another day. Take the load as far as you feel safe and park in a decent truck stop. Call the receiver on Monday and find out what's up. Day by day driver. There are a thousand trucking jobs out there. If they push you then it was never meant to be anyway. Be safe.
  10. kemosabi49
    10,449
    44,488
    Jan 13, 2013
    SW Arkansas
    I would get as close as I think I would remain safe. As said above, it you end up with you rig turned over it will be blamed on you. More important, you could end up dead. It's even likely there will be no one there to receive you and no power on either.
  11. FozzyNOK
    FozzyNOK Road Train Member
    2,452
    3,774
    Jul 18, 2007
    Oklahomistan
    Um.. why would this fall under safety?? They have a pretty sad case of refusal to work.. but that's not safety related at all..
