x15 Coolant sys pressure test. Not losing pressure after 20 min
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Brandon0928, Dec 5, 2022.
  1. Brandon0928
    Brandon0928 Light Load Member
    184
    105
    May 14, 2022
    Did coolant pressure test. Found coolant leak from clamps being loose around hose from thermostat housing. Tighten them up and leak went away. I had it at 15 psi. It never came down from 15. What would cause it to not release pressure?
  3. Brandon0928
    184
    105
    May 14, 2022
    Also tested CAC and found a leak there. Not sure if that’s relevant to pressure not releasing
  4. pushbroom
    pushbroom Road Train Member
    1,779
    7,317
    Sep 1, 2012
    If the coolant system has no leaks why would it come down from 15psi?
    Last Call and lester Thank this.
  5. Brandon0928
    184
    105
    May 14, 2022
    Wasn’t thinking I guess. I had watched a video and remember them saying you pressurize it and wait 5 minutes to see if how much pressure you lose . So I assumed after 5 minutes you slowly start losing it.
  6. lester
    2,920
    7,890
    Jan 2, 2012
    NW, Iowa
    Cooling system shouldn't loose pressure.
    CAC on the other hand, we'll it shouldn't loose pressure but I wouldn't expect it to hold pressure forever. I mean it would be great if it did but some loss is acceptable
    Brandon0928 Thanks this.
  7. Brandon0928
    184
    105
    May 14, 2022
    CAC has a pretty good leak. Can hear it hissing pretty and when spray soapy water it bubbles up good
  8. D.Tibbitt
    151,049
    What device did you use to pressure test the cooling system?
