Xenon lights(H.I,D'S)
Discussion in 'Trucks [ Eighteen Wheelers ]' started by freightliner15, Jun 3, 2011.
  1. freightliner15
    freightliner15 Light Load Member
    53
    Mar 12, 2010
    I have an 05 columbia and was wondering , would it be legal to put on an hid convertion for the lowbeams? I mean so D.O.T wont have issues with you...
  3. RockyWI
    RockyWI Medium Load Member
    441
    231
    Aug 10, 2009
    Wisconsin gal
    Why would you want to do that? :biggrin_2556: I would venture to guess that D.O.T would have an issue with it.
  4. freightliner15
    53
    Mar 12, 2010
    because my car has xenon lights and the visability goes up to 70% more in the rain
  5. Hammer166
    7,575
    27,616
    Aug 18, 2007
    ~8600+' and loving it!
    As long as the light has the proper codes on the lens, DOT can't say jack. Aren't the lights on a Columbia right out of a M-class Benz? That ought to make it a little easier to swap over, just find a wreck.
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Mercedes M-class with HID is equipped with projector type low beam and halogen (H7) high beam. Headlamp is with self levelling and AFL to avoid glare.
    But really ML headlamps fit Columbia.
    If you put HID in stock reflector type headlamps you make your truck galre monster, and headlamps are on average car windshield level. Try to imageine how many times you'll be cursed...
    jr-transport Thanks this.
  7. Hammer166
    7,575
    27,616
    Aug 18, 2007
    [​IMG][​IMG]
    Go back a generation or two, and the light housings are the same. And I assumed he was talking about a full swap, and was fairly certain the later model year ML's of that generation had projectors. Just sticking in the cheesy HID bulbs, which are indeed glare monsters due to the geometry differences of the light sources; is a bad idea. As bad as stock Columbia's are about glare, I hate to think how bad they'd be with just the drop-ins.
  8. Biscuit75
    Biscuit75 Road Train Member
    If an HID conversion is made it should be legal. I drove a 2010 KW T660 with the HID headlights. I've seen newer Vulva's with them.
  9. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    Not trying to be mean here--but if Columbia headlights(MBenz) are SELF LEVELING TO AVOID GLARE?????
    How come every one of those POS sorry excuse for a truck--headlights are out of adjustment????
    jr-transport and Roadmedic Thank this.
  10. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,981
    Apr 4, 2007
    Why do people use those irritating lights to begin with. So, they can see and others are not able to because of them.
  11. Colorato
    Colorato Road Train Member
    1,336
    865
    Feb 22, 2011
    DDM tuning makes kits that are plug in play. Just know what type of bulb you have and order there kit. All you do is remove the factory bulb, plug the factory bulb harness into the ballast and then connect the HID bulb. There kits run $35. I've had mine in my personal truck for over a year.
