XM ANTENNA location on 2012 Cascadia
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by ZippyNH, Dec 21, 2011.
  1. ZippyNH
    ZippyNH Medium Load Member
    408
    121
    Aug 8, 2010
    Southern NH
    Anybody find a good mounting method+location for an xm antenna on a 2012....the aero mirrors and the cb antenna's beaing by the sleeper is making it hard to find a good spot/mounting method.
    I currently have the antenna stuck to the top of the passenger side mirror (using the double sided foam sticky), and it works ok....too close to the side of the truck...this truck is a midroof....
    Anybody see any mounts that work or have any places that work good?
  3. fgb3
    fgb3 Light Load Member
    112
    36
    Nov 2, 2011
    elba ny
    My 2012 has its own xm antenna it came with the truck. Look on the roof towards the back on passenger side if you see a little black thing that's the antenna. I ordered mine with a xm radio so maybe yours doesn't have it but its worth a shot. If you see that black thing up there the other end is prolly behind your radio
    ZippyNH Thanks this.
  4. ZippyNH
    408
    121
    Aug 8, 2010
    Southern NH
    Thanks for trying, but no luck...
    guess that option was an extra $$ option, or only came when speced with a radio with built in xm.
  5. CanadianMoose
    CanadianMoose Bobtail Member
    13
    6
    Sep 7, 2011
    Toronto, Ontario
    Try a 90degree cb antenna mount where there visor bolts to the cab....
  6. ZippyNH
    408
    121
    Aug 8, 2010
    Southern NH
    Thanks, but no visor on the 2012's....aerodynamic improvement.
    thought of just sticking it up in that general area with some sticky foam, but then have the issue of a flopping wire...simply no place to run it behind.
  7. jessegobrowns
    jessegobrowns Light Load Member
    72
    25
    Jul 8, 2010
    Huber Heights, Ohio
    I found a thin L shaped metal the size of the antenna. ON the inside of the cab I slid it into the rubber and glass on the bottom of the front window towards the middle. bent the metal so it lay flat. The magnet holds its place fine. I don't have any reception problems from there.
    MUSTANGGT Thanks this.
  8. ZippyNH
    408
    121
    Aug 8, 2010
    Southern NH
    Sounds like i'll give it a shot...
    Tried that in my columbia, but didn't work....but with the bugger slopped windshield, i guess it might work better!!
    thanks!
  9. tech10171968
    tech10171968 Medium Load Member
    627
    851
    Nov 16, 2009
    Daytona Beach, FL
    How about a "bird perch" mirror mount? These mounts were specifically designed for the Cascadia and can be found in some CB shops. They look like a simple stainless steel post with a 3-inch thread on one side. You simply take out one of the screws from the mirror and replace with the post. They were created to solve the issue of Cascadia drivers having no way to install mirror mounted antennas on the vehicle. When I installed mine I found there was enough room to put on my XM antenna, and it works great!
  10. ecbaatz
    ecbaatz Bobtail Member
    27
    4
    Mar 23, 2011
    Edwardsburg, MI
    I thought about doing that myself but I thought having it mounted that low the cab would sometimes interfere with line of site for the satellite. Will keep this in mind, thanks.
  11. ZippyNH
    408
    121
    Aug 8, 2010
    Southern NH
    My thought and issue...
    i have it stuck to tge top of the pass side mirror...
    Going north or northeast i loose my signal...
    So i need it higher, or in a more clear spot....
    i tried to stick it just above the windshield today....ran the wire around the edge behind the weather stripping/gasket....
    I hope by getting it higher, and in a spot with a better, more realilable view of the southern sky (where the xm geostantionary orbited satellites are...).
    I'll post back if it works well....
